I will be using a set of speedmaster heads
It has .040 cast dished pistons so I am not expecting much for compression.
budget hot rod motor for my 75 d100.
that has great mid range power
and what do you expect the Scr to come in at?
and just how heavy is that D100?
With what rear gears/what trans.
It seems to me that you are looking for a miracle.
If it's mid-range torque you want, yur gonna need Pressure. But yur also gonna need the rpm to be at the road-speed that you want it to be at.
If it's power you want, yur gonna need all the usual go-fast stuff, including a hi-stall TC; and then the lack of compression won't hurt as much.
Rev happy will depend on what gears the beast is hooked to. Say like 2.94s will go from 1800stall @ zero mph to ~5400@60mph still in first gear.... with 29s. Not exactly rev-happy, if it takes 3 minutes., lol. If peak torque hits at 4000, that would be about 44mph, so, you'll have a bit of wait until the engine gets up on the cam. In other words;
for lack of torque, you need a higher stall to find where the power is, and you'll need to change the rear gear so you can use TWO transmission gears to get to 60 mph. Of course, that means no more hiway cruising with a 3-speed auto.
Ok so, have you priced a new TC and gears, installed?
How does that compare to a proper zero-deck block with flat-tops, and small closed-chamber heads? It doesn't take much to get a 360 up to in the range of 10.7 to 11/1, which you can then parlay to pressure from 175 to 195. as compared to ~120 and less, with the current combo, and some of the recommended cams.
And then you can run a serious cam, and smoke the tires, maybe, all the way to 60 mph. From there you can fine tune the rpm to the speed you need it to be at.
Ok now, the thing is this,
at 120 psi yur 360 will be a turtle on the rev-happy-in-Neutral, scale.
Whereas, at say 185psi, a good number IMO, it will hit the rev-limiter with authority.
Yes, you will, need a rev-limiter even with an automatic, cuz that engine, without the recommended oiling mods, will not make many trips past 6000 before it starts throwing rod bearings.
You can skip all this foolishness, and just put the stock top-end and cam back on/in it, but with a 4bbl, and I would still run a free-flowing exhaust, (headers preferred), and stall the beast at about 2800. Then, maybe later, get some gears.
IIRC the factory cam is about 252/262/112 Peak power might be around 4500 rpm, but with the big-port heads, and a 112Lsa, that should pull to 5000 in your application. With 2.94s and 29s that comes to about 56mph @5000 still in first gear. and cruizing, 65=about 2300. Give her the timing she needs and lean her out, and see what happens.
These are my opinions.
Yur gonna do what you want anyway, so ......
Let the flaming commence. I ain't coming back.
