blackace
The KING of flats
Does anyone sell replacement motor mounts? I tried Mancini and Summit and also Ebay and come of with ZERO!
I use a solid mount on the driver side and a rubber mount on the passenger side.
Solids are about $25 a pair and the rubber mount should be under $10.
The brackets are used only. Try Pming Crackedback. I bet he has a pair he will sell.
The engine torque tends to pull the driver's side mount apart, so a solid mount holds together better. The right side is pushed on, so a rubber mount will hold together fine, is cheaper, and will help keep the engine vibration transfer to the passengers down a bit.
