Babyblue66
Cool dude
The rebuilt 273 is coming out for a rebuild. Yes, a rebuild.
The cast after market pistons being .045 in the hole, .040 gasket and 65cc chamber equals an astounding 7.7 to 1 compression.
So hopefully get some descent pistons, deck it for some quench, add a nice solid cam, the Perfomer and 600 Holley I already have, balance it and she'll be cruising the streets at a leisurely 6,500rpm in no time.
Also getting an 8.75 with 3.55's, front sway bar, 340 duster springs, fatter tires. Probably not this winter, but if the budget permits the 4 speed from above mentioned Duster.
Or should i put this in? ha ha
