Mopar King
Beginner / Need of Help
I know this is a dumb question but I have to ask you guys out for a little help. Also if I'm using the incorrect word terminology please correct me
I been looking on line and for some reason I can't seem to find a 9 inch front drums with the hub assembly anywhere. I ordered and got both the inner and outer 9 inch bearings from Autozone but when i ask about the 9 inch drum brakes they told me that they have been discontinued/out of stock.
I tried ordering one from summit but got the wrong set - They didn't have the hub to hold the bearings. I am also seeing in most auto store websites the pictures aren't clear and can't tell if its the drum with the hub. I got two other part numbers but descriptions are not too specific and the summit picture is showing a 4 bolt pattern (yes I read that the image is a representation and actual item may vary) but it still makes you think and doubt.
This is for a 1971 Dodge dart 4 door sedan - Slant six and small bolt pattern, All drums
http://www.classicindustries.com/mopar/parts/2956.html
http://www.summitracing.com/parts/axt-ax8190/applications/make/dodge/model/dart?prefilter=1
