I did ask about that and he said they should not be spinning.seafoam? on a new build? I dunno, sounds like a Hail Mary to me. Are all the pushrods spinning when engine is running? That's important to know.
They are 100% wrong. Paint the dots on them and check each one out.I did ask about that and he said they should not be spinning.
if it's a roller cam, no, they should not be spinning. But if it's a flat tappet, solid or hydraulic, they better be spinning or you'll end up with a dead cam and lifters, and a bunch of metal mud circulating past all your bearings, and polished journals.I did ask about that and he said they should not be spinning.
you don't have to ask anybody, just pull the valve covers off and watch them with your eyes.I have to many of you telling me they should so I'll ask again.
Oil up through the pushrods? isnt that a small block Chevy thing?...
And that is why the majority of push rods you'll find have oil holes.The number of engines that used pushrod oiling through the years is probably uncountable. Chrysler is among them.
not that long ago, member WSUtard, had a couple of "soft" lifters. That, and incorrect preload. Went to adjustable rockers, too.Just to add one more potential cause: the lifters themselves can fail so as to not pump up and hold oil properly. Then they will tick. My son had one on 340 that started ticking after about 700 miles and it just got worse. Replaced it and things are good. This is a common problem these days.
Yes, I PM'd him and asked to have them, and he sent them to me. 'Someday' I am going to try to figure what is going on with these hydraulic lifters crapping out.not that long ago, member WSUtard, had a couple of "soft" lifters. That, and incorrect preload. Went to adjustable rockers, too.
