318 Poly Flow Test
It is a borrowed head from a 318. I don't own it. It would be a more fair way to compare ports however.
But You really ought to be using the bore they were designed for, 3.91", a .030" over 340 bore isn't OE representative......to be accurate..
I flow all my small block heads on a 4.015 bore. Even my 360-1 heads that I run on a 4.100 bore.
That's the best MO, You work those & get great #'s in a tight bore, most cases it only gets better from there...but being these are totally different design heads, I'm curious how they compare with the closer bore proximity, strictly flow-wise anyhow.
You are correct.
That made me think of an somewhat related experience on the bench with the Speedmaster head. PBR told me some months ago about the importance of flow around the shrouded side of the intake valve. So now, quite often when I make a change to the head I will flow it with the locating pins holding the head in the proper position then take the pins out and shift the head about 0.040” just to see what happens when the valve is unshrouded a little more. To my surprise, peak flow often went down when the head was moved. I finally realized that at peak flow (since the flow in my head backs up/rolls over about 0.650 lift) the air needs containment. It needs surfaces to control flow separation. By moving one of those controlling surfaces farther away, flow separated earlier.
The same could be happening with my 318 heads on the wrong bore size.
Good observation on your part.
Thanks Earlie A for these tests. Very interesting to say the least. It's true that the Poly was never built as a "performance" engine. However, that doesn't make it an engine with zero potential as some say! In fact, the opposite is the reason I run with one. Also, there are obvious reasons why there are distinct similarities between the Gen3 Hemi head layout and the Poly which have been well-documented.
As to the weight issue, a complete Poly engine is 55 lbs. heavier than an LA engine (depending on the source). Heavier yes but a major issue, No. Yes, I'm Poly-biased. I have a .030" stock bore Poly (.323 CI) with forged pistons, balanced rotating assembly, larger (stainless) valves, ported heads, Full-length headers, Magnuson twin-screw supercharger and a Tremec 5-Speed in my early 65' Dodge D100. I intentionally didn't take the stroker route as it's more fun to tell people it's a 318 Poly that just dusted them!
- EM
- EM
Post a picture. Sounds like a great set-up.
Not really an A-Body thing, but a cool engine none the less. My first car was a 1966 Coronet 440 with a 318 poly. My father bought it new. I've had the heads in the shop for quite some time, and I finally took the time to rig up the valve opener and flow test the intake. Small ports and not much flow, but these are cool heads. Nice, centered, unobstructed intake port. Combustion chamber with canted intake valves and quench area on both sides. Short, direct exhaust port. Nice design for the 1950s.
Flow numbers are attached. Flow numbers from an iron 360 head with 1.88 valves are included for comparison. Poly has 1.84 intake valve.
What is the springs installed height. The 1.88" Magnum valves could probably be installed easy enough. For low cost the LS 1.9" intake could also be employed. Get the GM powdered metal guides or bronze. If the installed height is about 1.8" the LS beehive springs, retainers and keepers can be used.
Looks like the port shape should work really well, just needs to be bigger.
Port volume is not the answer all the time. Flow velocity and energy density are more important. These provide cylinder ram filling before the intake valve closes as the piston is rising.
Stock it's around 1.625. That's with a tape measure.
Should be 1.800 OEM installed height from my research previously. I used Pro-Flo stainless valves from REV @ 1.60 / 1.94 with Manley springs and retainers. Camshaft is a reground OEM by Oregon Cams to a Schneider profile I provided. Dale is correct also with regard to using the LS intake as that was done by one of the Engine Masters teams in their Poly build. I'm also running full-length stainless headers for a 302-351 Ford that I made adapters for.
Neither is strangling your engine, it's about the right volume, and the right ain't always optimal it's depending on circumstance, goals, compromise etc... And it seems not as sensitive as some make out.
There's a lot of things that are important, and generally compromises need to be made.
My 1966 Ford 289 installed is about 1.65". I talked to PAC springs for a recommendation, standard dual springs, not beehive. Summit hooked me up with 1.9", 1.55" valves with retainers and keepers for the Chev valves. Now need the money for the machine shop to install bronze guides and do the valve job going from 1.78" intake to 1.9" intake. Ordered the springs through Summit as PAC does not sell to private citizens.
The difference between 1.625" and 1.8" is very obvious with a tape measure, enough to know the beehive are not an option.
Then valve length is to be considered. Chevy are about 4.9", a bit shorter than my Ford valves. Worst case to get geometry correct will be lash caps.
Something to think about. I know the purists will be having a hemmorage over Chevy parts ruining a Mopar, but sometimes you have to look at what works for an inexpensive upgrade.
Dude, wtf does that have to do with comparing a Poly head to an LA head? And if You're a Mopar Guy with all of these tech answers, how do You not know or have a reference at Your fingertips what the installed ht. Polys have...??? Gary Pavlovich & crew have probably done as well as will be done with a Poly, with some modern upgrades, it may cough up a few more hp....but at what cost?? You should look up the Chrysler Power articles & anything related to the PolyPac folks, including the one run in the Engine Masters competition.....it's been done..
This was supposed to be a comparison thread, I thought anyways,......trick valves, custom lengths & springs can be done to ANY head....what is the comparison in results 'twisted wedge before twisted wedge was a thing' Polys vs inline wedge LA 'teener heads.
OOOH, someone got out of the wrong side of the bed. Maybe time for an afternoon nap today, get your beauty sleep, eh.
Earlie A was comparing two heads and mentioned valve sizes. I just post a possibility that is inexpensive to a degree. Yes machining to put the 8mm guides in is costly. But good chance those poly heads are due for guides anyway. Whether you chose the Magnum or LS valves, the smaller stems provide much lighter valves. I would venture the LS have a lower cost.
Intake flow is area ruled up to a lift of 1/4 the effective valve diameter which is 0.91 × measured head diameter. So a 1.84" valve has an effective seat diameter of 1.6744". That × .25 is about 0.42", so the valve is in most cases the limiting factor in port flow up to that lift. At higher lifts the port flow is more the limiting factor. Old engines only had about 0.375" lift, so big ports were not required. Stovebolt Chev 6's only had 0.3" lift, definate tractor engines.
Your choice what you want to do with that information.
Take your dumbass drag racer crap out to the strip. Also quit beating your wife!
Who said anything about drag racing. We are talking street cars.
Unfortunately you don’t have the gene that lets you think logically. You spew a bunch of bullshit.
Have a nice day.
While Your quoting DV for the basic geometric relationships; port form, orientation, inclination, & placement all affect what happens at the most important element...the valve job/throat form. It doesn't take as much lift as You think for the port/design/chamber to have a sizable effect.
And My bed has no bad sides, it's all good, peace!
Have a nice day.
Cause he's possessed by DV, it's all what DV has said, but hasn't seemed to form any of his own opinions on anything.
