Re-powered with a 2001 360 Magnum with the following mods:
Vortech V-1, S-Trim blower
Carb Shop 4150-type Holley 750 double pumper, blow-thru modified carburetor
Air Gap intake
TTI headers and exhaust system (2.5"), Dyno-Max Super Turbo mufflers
Hughesengines cam: Hyd. roller (DUH!) with 214/218-degrees of duration @ .050"-lift[ .525" total lift
Crane roller-tip, needle-bearing rockers; chromemoly thick-wall pushrods and 300-pound (open) valve springs from Hughes.
Pocket-ported heads with a...
Air Gap intake
Log in or register now.
