If you're using a LA oil pan then yes, you'll need to fill those front "notches" with siliconeAlso do you have to put the gasket maker here for it not to leak?
I am not sure there is any header that will work on an early A, thats why I am building my own for the 64....was going to have them made,, as well as my headers I built for 67+ that works with PS but my guys that build our jeep swap headers want $700/pr if I order 10 at a time plus $3K jig fee. These are gas welded by hand using 3/8 flanges with virgin USA steel, they fit great, do not require engine removal and wont leak, they also dont require breaking steering linkage loose as they are above not below linkage and dont hand down. I dont know how long it would take to sell 30 sets of headers at $900 just to make $100/set which is about 11% profit before cc charges. Still looking for a company to built them for me for something closer to $500/pr. The early ones I might be able to sell because there is nothing else out there but not willing to gamble $10K to find out. Dont really want to have them made in Mexico or ChinaWill the long tube work on early a? Have a pic of them?
I'm running a stock 2000 5.9 EFI out of a Dakota RT in my 65 Dart. I'm running the 273 exhaust manifolds. How much HP gain could I expect from a cam swap and having you do your thing on the computer?thats like installing a sun roof in it.....you will hate yourself in the morning, or at least next time it rains. Unless I was installing more than 325 HP, I would stick with the 273 manifolds. I cry every time I go check out a car to build and it has/had fender well headers, then I head home with an empty trailer.
Awesome build!
Thanks JeepJeep,
Unfortunately this has turned into 10-20 business day build. Been too busy with the A body and Jeep swap stuff to really work on the car. That on top of waiting for parts so we don't use up too much stock its just beem crazy.
-J
I tend to be quite conservative o my HP estimates. Nobody is ever disappointed if they dyno and get 30 hp more than I said but if its 30 HP less....FI and Carb will be the same HP, FI will have more torque sooner due to better air mix.How come there are descrepancies between carb horsepower and fuel injection horse power. From what I read they should make 400-430 with a carb.
Okay I wasnt imagining things. It was over in the 64 Dart GT swap thread. His experience/post noted that:
The manifolds will bolt right on but will have a 1/4 inch open spot underneath where there is a port mismatch. These are the 69 hipo manifolds I'm talking about.
I made 14 gauge steel plates and cut the hole to fit the head port size and the cut the outer edge to fit the manifold.
A better bet would to use magnum manifolds, if you can find some to fit.
Yay, nay?
