some bushings need to be finished reamed to fit properly
I ordered a new pump and a new bushing. I think i remember there being a slight tear in the oil pump gasket and i i just added a bit more sealer, so im hoping that is the culprit since everything else has been ok as far as plugs go.The bushing is a press fit....if it came out, that's a problem
A slight tear in the oil pump gasket would be a BIG no-no a little sealer ain't gonna fix thatI ordered a new pump and a new bushing. I think i remember there being a slight tear in the oil pump gasket and i i just added a bit more sealer, so im hoping that is the culprit since everything else has been ok as far as plugs go.
Jake
Yeah, i completely forgot about that and its hopefully a lesson learned.A slight tear in the oil pump gasket would be a BIG no-no a little sealer ain't gonna fix that
But it should come out of the block without some major effort . Certainly not just by pulling out the Intermediate shaft....
Am I wrong ?
I did this and it stopped right at 7 3/8. Im assuming that means the plug is in there?
Jake
I didnt but is it possible that a faulty oil pump gasket could cause an issue like this?
Jake
Ok, thanks for the heads up. I'm waiting to pull the engine hoping there is something I'm missing completely and Is very obvious. The other thing I'm going to check is possibly a plug in the oil filter galley, I stared at it and thought it looked different from the other builds i have done but that thought came and wept.I use a piece of all thread with 2 large thick flat washers to pull the bushing into the block, if you don't have any assembly lube put gear oil on the outside of the bushing and a little in the block and the bushing will pull right into the block. Don't hit it or try to drive it in, its oilite brass and can easily brake if you try to drive it in and it can also
damage the top and the shaft wont go in or will be tight, I have been doing this way for years and never had to ream one.
Thank you for your help.Yes, now it's move on to other possible issues
boiling out a block will not affect a steel plug, and if that plug is missing, oil pressure is not lower-the filter is bypassedWas your block boiled out? That oil galley plug could be the culprit.View attachment 1715034814
I tend to disagree. When a block is boiled the plug looses it's size and gets loose in the bore. It doesn't take much and you have low pressure.boiling out a block will not affect a steel plug, and if that plug is missing, oil pressure is not lower-the filter is bypassed
at what temp are you boiling blocks? and if that plug is left out completely , the filter is bypassed, oil pressure is NOT lowI tend to disagree. When a block is boiled the plug looses it's size and gets loose in the bore. It doesn't take much and you have low pressure.
Its a mopar oil filter ive used in past builds, worked fine for the last 15000 on my commando.Maybe irrelevant, but what oil filter are you using? Hope it's something simple...
are you saying a block to oil pump gasket ? wouldn`t it leak where it could be seen ?I didnt but is it possible that a faulty oil pump gasket could cause an issue like this?
Jake
hell of an idea !I use a piece of all thread with 2 large thick flat washers to pull the bushing into the block, if you don't have any assembly lube put gear oil on the outside of the bushing and a little in the block and the bushing will pull right into the block. Don't hit it or try to drive it in, its oilite brass and can easily brake if you try to drive it in and it can also
Thanks steve, me too! Im going to pull it this weekend, im hoping for the best.Following along. Hope its a cheap fix Jake. Good luck
Jake
Yeah, I put all the necessary plugs in from the kit but the culprit looks to be the pump, at least that's what I'm hoping for.Did you put the two plugs behind the cam plate?
