looks great, I like the deeper dish, but that doesn't allow tire rotation front to rear...a 3" wider rear end would take care of that....XJ 8 1/4" rears are 3" wider....These were not taken from a great angle but you kind of get the idea. Vision 143, 18x8.5, +32 front, -6 rear.
That's certainly an option, I'm working with what I got. Someday I may move the springs in board and widen the wheels which makes rotation a moot point. But, you are correct.looks great, I like the deeper dish, but that doesn't allow tire rotation front to rear...a 3" wider rear end would take care of that....XJ 8 1/4" rears are 3" wider....
So here is another curve ball.. I just found a B-Body 8.75 it says 68-70, will the 489 center section off of my a-body unit interchange?
That's exactly what i want to do.Yes, the 489 pumpkin will interchange fine.
The nice thing about the wider B-Body axle is you might be able to use the same wheel on the rear as the front if they are both higher offset. That's how I can run a square 17x8 +30 setup.
