Ok investigated Super red ram is a 270 CI Hemi engine. The red Ram is a 270 CI poly head engine, Debuted in 55
1955 Dodge engines
There are three engines used in the 55 Dodges - the
Getaway Six, the Red Ram V8, and the super Red Ram V8. The flathead six displaced 230 cubic inches. The
Red Ram V8 was a polysphere (single rocker shaft) and was used in the Coronet V8 and Royal series as standard equipment. The
Super Red Ram V8 displaced 270 cubic inches (like the Red Ram V8) and had hemispherical combustion chambers. This engine had double rocker shafts and old timers called it the "double rocker" instead of the more familiar "Hemi." The Hemi is standard on all Custom Royal series and is optional on all Coronet V8 and Royal series cars. The two V8s share many internal components, and will accept manifolds and other components from the 53 and 54 Dodge Hemi of 241 cubic inch displacement. The six is a flathead and definitely not state-of-the-art for 1955. I have driven both Red Ram and Super Red Ram Dodges and can honestly say that there is a marked difference in performance. The late fifties were a time of inflated horsepower figures, but the 1955 figures were based on engines with accessories and were even a bit conservative. The Super Red Ram could be ordered with the power package (4 barrel, dual exhaust) which puts it way out ahead of the Red Ram in terms of power.
The horsepower figures were measured with these power consuming accessories: generator, water pump, manifolds, fuel pump. The Red Ram has low friction valve locks to allow for valve rotation while the Super Red Ram does not have a special provision for valve rotation.
The power package is a very rare option. The Carter carburetor is of a surprisingly modern design with metering rods on the primary jets and velocity valves controlling air flow to the secondaries. This is very similar to the Carter AFB, the carburetor used on the 426 Hen-Is. Dual exhausts were also part of the power package. No other modifications were made to the engine when the power package was installed.
