1962 A body engine mount BRACKET
Slant 6 Engines
  1. barbee6043
    barbee6043 barbee 6043 FABO Gold Member
    13,327
    5997
    Jul 20, 2008
    Shepherd, Texas ( SE Tx)
    Local Time:
    10:14 AM
    Took them off 2 years ago and I can not find them anywhere. I have what I believe is a correct bracket for the left side but I am pretty sure the right side is different than the ones I have (which takes a rubber mount that attaches to the bracket with 2 bolts). I think I bracket I need the biscuit attaches to the bracket with one bolt.
    Anyone have a pic of the brackets or have that side or a pair I can buy?
    I think the 62- 66 K members are the same for A body?
  2. 69FBCuda
    69FBCuda Life in the Fast Lane FABO Gold Member
    2,866
    1518
    Aug 28, 2014
    Florida
    Local Time:
    11:14 AM
    65 Barracuda SB
    • Thanks! Thanks! x 1
    • barbee6043
      13,327
      5997
      Jul 20, 2008
      Local Time:
      10:14 AM
      No.... its a slant six.
    • valiantpatrol
      valiantpatrol FABO Gold Member FABO Gold Member
      1,041
      167
      Apr 21, 2009
      Tucson, AZ
      Local Time:
      9:14 AM
      In both pics the one on the left is the left hand bracket and right is on the right. If you need one or both of these start a conversation.
      • nitro_rat
        nitro_rat FABO Gold Member FABO Gold Member
        105
        30
        Apr 25, 2020
        Texas
        Local Time:
        8:14 AM
        I might have what you need, picked up an aluminum slant over the weekend and I know it has at least one of the mounts on it. I'm working in Houston this week but give me a call on Saturday, I'll go have a look at it. I think mine is a '62.
        • barbee6043
          13,327
          5997
          Jul 20, 2008
          Local Time:
          10:14 AM
          So those are correct for my 62 Lancer? '62 thru what 66 takes same brackets? When I search Rock Auto for the rubber mounts it shows a mount that attaches to the right side bracket with one bolt not two like yours and mine take. I have those brackets and their rubber mounts.
          I guess the slant will drop in no problem but it sure looks off!
        • valiantpatrol
          1,041
          167
          Apr 21, 2009
          Tucson, AZ
          Local Time:
          9:14 AM
          Based on your description it sounds like Rock auto has the pics mis-identified. The mount with two 3/8-24 attaching studs is for the Right side. The left is the one with a single 1/2-20 stud sticking out in opposite directions. If what you have matches the pic I sent, yes it will bolt right in to your Lancer with the proper rubber insulators. And yes, '62-'66 SL6 all use the same (pictured) brackets and the same rubber insulators.
        • nitro_rat
          105
          30
          Apr 25, 2020
          Texas
          Local Time:
          8:14 AM
          Wow, triple post! Nice job
        • valiantpatrol
          1,041
          167
          Apr 21, 2009
          Tucson, AZ
          Local Time:
          9:14 AM
          My internet is more wonky than usual lately. The downside of rural living, at least in SE Arizona. I saw that triple post and freaked out, but was able to correct it.
          • barbee6043
            13,327
            5997
            Jul 20, 2008
            Local Time:
            10:14 AM
            Thanks for the info. Last time I dropped in a slant was like 5-6 years ago. I admit I have pulled and dropped in maybe 8-10 over the decades but I have forget half what I did know!! lol
            Pulling the slant out of my 62 Dart( B body) did not help as I get parts all mixed together!!
            Thanks again slant guys!
          • Hyper_pak
            Hyper_pak Old School Chrysler Fan
            3,132
            2354
            Feb 14, 2010
            Desoto Texas
            Local Time:
            10:14 AM
            Bill, I had a problem on the oil pump side on my 62. I had been running a 67 before, so it sounds like the 62-66 info is good gouge. There is a little kick in the early bracket not in the 67 up one. Here were my mounts. Left one is 62, right 67.
