Hope you don't mind me sharing this here Rob, but I wanted you to see where I am
Of course you can! It sounds great, Mike!
Thank you, it was important I knew you seen that video, late evening putting her back after a family and friends get together.. good food and listening to my two boys and granddaughter yack.Of course you can! It sounds great, Mike!
Thanks! Slow as molasses, but still going forward!Good to see things moving forward on Vixen.
I thought about that. I'm also thinkin the pair under Vixen now and the pair I have to rebuild made it this far without them. So what's 60 more years? lolI bet you could run a couple straps instead of a complete plate??
Did you put them in Vixen ?And of course now I cannot find my control arm stiffening plates. No tellin where they are. They're gonna be tough to find too because they're flat. Dammit all. lol
Naw, I have the bolt on ones that bolt to the shock bolt. I actually like those, because you can kinda angle um like you want um.If your luck is like mine, you put them where you could find them....and you know the rest of that story! When I quit looking for something is when I usually trip over it. Do your sway bar tabs bolt on or will you weld new ones to these arms?
I used the Addco bar, but I used some universal mounts from Energy Suspension, because the attaching hardware from Addco is chinsey, but the bars themselves are good.I need to read back thru your thread here and see which front sway bar it was that you used. Seems like I remember you being pretty happy with it, and I need to get one for my 65 Barracuda.
Same here, never on any of my E bodies or A bodies, but I did have one loosen up on a ramcharger not long ago.That's very strange to me.
In all my time with dozens of Mopars over dozens of years, I've never had a steering box loose.
...and I drive them pretty hard and even off road sometimes.
I never have either. Or at least, not that I noticed.That's very strange to me.
Mine still moves a VERY slight amount. So, when I put her down for the disc brakes, I'll be doing some reinforcement to the K frame too. You do know there's a factory reinforcement bracket to fix your problem, right? I actually have one to go on my rat truck.....IF I ever finish it. lol@Jim Lusk My 88 D100 2WD steering box wiggles because the frame is cracked where the PS box bolts on. Gonna fix it when I install the 5.9 Magnum.
Thanks! That's puzackly the piece I was talkin about. I was trying to find where I got it from and you posted it!
Yep...it has a brace on it already. I did like you, and got my wife to turn the wheel while I eyeballed it. Chunk of the frame flexes back and forth. I plan on downing it this winter and fixing it. I have a good running, low mile 5.9 Magnum with all the wiring and computer to install, so I'll fix the frame and get the steering box to sit still while I have it apart and have some room to work.Mine still moves a VERY slight amount. So, when I put her down for the disc brakes, I'll be doing some reinforcement to the K frame too. You do know there's a factory reinforcement bracket to fix your problem, right? I actually have one to go on my rat truck.....IF I ever finish it. lol
