1965 Dartcharger
Interesting your firewall clips to hold the wiring harness are black. I had faded white clips on my 65 and faded blue clips on a 65 4 door sedan I parted out. Interesting that my wagon and the blue 4 door were/are CA assembled
It's only black on the clips holding the wiring and vacuum hoses on the passenger side. The orher ones are painted body color in this case. As you can see there is a gap in the painting due to the clips.
So the black phosphate clips only hold the vacuum and AC wiring. I will still use my white clips. In fact I will use aa couple of extra clips.
Yes, black clips for optional equipment only. Standard wiring in body color.
Do you by chance have a center hood emblem in mint condition?
So I learned something new today about those clips. I will still run the heater/AC wiring/vacuum hose along side the main harness with the body color clips. I don’t think anyone will notice; they’ll be too busy pointing out the other things that don’t appear stock!!
I have only one center hood ornament (and one driver's side DODGE emblem); both are NOS that i’ve saved for years
I guess they are for your one-of- none 1965 Dart Delivery. They will fit like a glove.
Two weeks ago I was able to buy some new NOS parts. Lenses, tie rod ends, cam package antenna bezel, hood and truck hook and the most unusual thing so far, an NOS master cylinder cover. First time ever. On my other Dart Charger I were able to locate and buy a NOS complete master cylinder. But this one I think is over the counter part by Mopar. Test mounted one time and put away.
Any one seen this color before? It's the same as the hook for the hood.
Today I've been able to mount the body in the rotisserie.
First thing was to take of the stainless steel moulding that holds the vinyl top under the roof moulding. Need to find out if the clips are the same for vinyl top or no vinyl top. One was damaged and can't be saved.
But I enjoy that I finally can work on the body in an easier way.
The emergency brake cable had an odd twist. The grommet passing the inner fender shield/firewall was mounted backwards!!
I wonder if this car has been a test mule for a dual exhaust system experiment? I don't know but someone did an excellent job on both sides on the rear valence panel.
Speaking cutouts I wonder if I’m going to have to add one for the reasonator?
Finally the next project showed up today. Rostfree body, toasted interior and lots of work.
Need to list all the work to fire it up. More pictures to come.
Ugh this makes my heart hurt. I know what you are going to go through making it sweet. I just got mine painted. It took 7 years for a complete restore! UGH!
New challenges! The engine block is hot tanked and looks great. Casted November 4, 1964 and assembled November 30 same year. However the person who assembled the engine forgot to lock one piston pin on one side. There is a big scratch in the one cylinder so it needs a sleeve.
Dang!
Yep, a sleeve will take care of that and only you, the machinist and the block will ever know it’s been sleeved. It’s done every day
The body is finally empty on all parts and ready for waterpolishing now on Tuesday. The whole body is intact except lower inner fender box. But I should not complaine.
The a/c knobs are clear plastic but Dart never had these lightened. Hmmmmmm!
Ready for aqua polishing or water blasting. Not sure what's the correct word for it is.
Anyway first time off with this method.
I wonder if some kind of fiber-optic filament could be used to light those knobs up?
I have a 62 Chrysler pushbutton assembly . I was told it had a light housing under the knobs that took a common dash light bulb which kind of lit them up with the translucent part of the knobs acting like a rudimentary finer optic. Unfortunately, I don’t have the light housing.
