MoparDaddy
Damn Right I Carry!
Yes, almost all the car carpets available on the North American aftermarket are made by ACC. Best vendor I've found is stockinteriors.com . Highly recommended.
Thanks for the heads up Dan!
Also ordered carpeting for my 87 D100 from another company and it too came in an Auto Custom Carpet box.
Here are the pics, it actually looked pretty shiney to me. :glasses7: I know some stainless trim looked good but not sure if they were over polished to a perfect mirror shine. I know this trim had some small flaws in it, but still looked awesome!
My guess at how the process might've been done to arrive at a 1-side stitch like this: Plastic starts out as flat strip. It's overlapped onto the hardboard panel, sewed, then the plastic is heated and bent into a channel shape around the edge of the hardboard. Perhaps more clues will present themselves when the plastic is removed from the hardboard.
Reproductions here and here (and likely made by REM and available thru Dante's). Don't know if any of these repro sources would include the plastic channel, though; you'd likely have to remove it from the originals and transfer it to the new ones.
Here is the valve off of my 65 convertible made in L.A. Ulf you know the date my car was made. Thought i would add the other valve cover also.
Forgot to tell you Ulf but you have a package on it's way!!!! Shipped it a few days ago.
During my research I have found out that Chrysler added oil filter decall on all the 1965 2 barrel air cleaner. But what about the 273 4 barrel air cleaner?
These are the ones that I have found. Was it all plants that used that decal or was it some line at different plants. But the question remains, which decal was used on the 273 HP engines?
Any help is appriciated.
Battery warning tag: Yes.
Coolant decal: top or 2nd from top, not 3rd from top.
Thermostat temp decal: really bad "reproduction"! Uppercase letter O used instead of numeral 0, corners rounded instead of sharp.
Wow! Very cool project. Look forward to seeing how it turns out. Looks like you had the same amount of body work as my 64. I like seeing what you did under the rear fenders.
