JGizmo
That looks like an awesome build! What have you done to it?
That's not my car. I just have that hood on mine.That looks like an awesome build! What have you done to it?
I see, where'd you manage to get ahold of a hood like that?
Really?! Hahaha I think I still have a lot to learnI like it. Your welding and fab work is probably better than more than 90% of the members here.
I can just hear those Nova guys going “Who was that masked man?”
I hope so, hoping for 375 whp. Might do a nitrous setup as wellRad dude, that 6.0 outta haul the mail in the Valiant.
Where in Cali are you? I’m building a 383 for my 74 swinger, should be similar HP. We should meet up when our cars are done.I hope so, hoping for 375 whp. Might do a nitrous setup as well
That's awesome, I'm actually pretty close to you. I'm about 15 mins south of Santa Rosa, so around an hour and a half drive. Starting college tomorrow so progress might be slow on my car but I think I can have it running relatively quick if I hammer it out.Where in Cali are you? I’m building a 383 for my 74 swinger, should be similar HP. We should meet up when our cars are done.
Sounds like a Mopar meetup at Lagunitas is in order. Count me in!That's awesome, I'm actually pretty close to you. I'm about 15 mins south of Santa Rosa, so around an hour and a half drive. Starting college tomorrow so progress might be slow on my car but I think I can have it running relatively quick if I hammer it out.
Sounds goodSounds like a Mopar meetup at Lagunitas is in order. Count me in!
All that custom work for the same HP or less than a 360. Cutting, Welding, Custom parts, Crap Chevy drive train. What a waste.
Sure there is. Let me just go play with those dyno settingstheres no stock 360 putting 375 to the wheels .
Im pretty sure the Magnum 360 was the highest HP stock 360 and I don’t think they even made 300 hp at the flywheel.Sure there is. Let me just go play with those dyno settings
Nice fab work! You probably are already planning it, but you should tie the torsion bar/transmission crossmember back together over the top once you get your transmission angle where you want it. A piece of flat bar over the top of the tail housing on the trans, welded to the cut ends of the original, then new floor pan spot welded to that should be enough.Hey all, I've got a 1965 Valiant, and I planned on putting a 5.3 LS in it. Well that didn't work out, so I bought a junkyard 6.0 LQ9 Vortec out of a Cadillac Escalade. While technically not an LS the Vortec only has minor differences, and I think it was a better choice budget-wise. Over the last few days, I've completed fabricating engine mounts and a transmission mount, and I have everything set in the car. In order to keep costs down this build is very much an amalgamation of parts left over from my coworkers' other projects, though as the car progresses I'm sure I'll upgrade a lot of the parts. Since I just made it over the first major hurdle of this project I figured I'd make a post. I understand this isn't for everyone, but for anyone who is interested I'll attach some photos of my progress from the last couple of days, and I'll try to be detailed about the setup.
As I mentioned, this is an LQ9 out of a 2004 Cadillac Escalade. I chose this over the LQ4 as it has flat-topped pistons giving it a higher compression ratio. I've got an LS9 camshaft in the engine with upgraded pushrods, rocker arm bearings, and valve springs. I used a center-sump oil pan from Sikky (needed an LS1 windage tray to fit the pickup tube). Using this pan I was able to clear the steering center link. As for K member clearance, I only had to beat the frame with a sledgehammer for an hour.
Here is one of the motor mounts I built. This was my first time welding so go easy.
As you can see I've used the factory transmission mount. I cut out the center section to give room for my new transmission and welded some reinforcements.
I went with a Tremec TR3550 transmission and a 621 SBC bell housing, and the mounting holes only had to move a few inches forward.
In order to get the 3-4 degree driveline angle I needed, cutting up the floor (and chopping a few ears off the transmission) was necessary.
I've still got plenty of learning and work ahead of me which I'll continue to post about in the future.
