Anybody ever use a 1966 D-Dart Holley Carburetor for the Drag Strip.
Holley #3778 - Model 4160 - 700 CFM
Manual Choke - Vacuum Secondary - Single-Inlet Fuel Feed
Primary Throttle........ 1 11/16" {1 5/16"" Venturi}
Secondary Throttle.... 1 11/16" {1 3/8" Venturi}
Primary Jets..............122-75 {.081"}
Power Valve..............125-65 {6.5}
Primary Pump Nozzle..{.025"}
These Holley Carburetors were 'specially produced' for the D-Dart, and were not found on
any other Engine application.
The #3778 was 're-calibrated' by the Dodge Factory Technicians.
Date Code Tags are early 1966 manufactured dates.
