Joe Mc
No Car Like A MoPar!
Seam sealer. I've used and like the Eastwood stuff. May I suggest: 1-primer then seam sealer, flatten down a bit with a throwaway brush dipped in lacquer thinner. 2-after cured then finish paint.
PST is a vendor here and may be able to help. The gears can be adjusted and there are quicker gears but along with that they are harder to steer.Probably will not convert to power steering. Its not bad at all on this little car. But will replace all the rubber and ball joints etc. its a bit loose. Maybe somewhere the steering box can be re geared for a little quicker response? I do not know.
Haven’t done this kind of stuff since I was a kid, so a bit out of date….
Yep. It's a pain. You have to stand on your head to open the trunk.Can someone advise if this is normal. The rear deck trim comes over the lockset. I know these cars weren't perfect. Previous owner lost the key and I just got a new trunk to install from Van’s.
Not sure if all auto-body supply places will do that. There's one in Levittown, PA, back where I used to live (Flannery's Auto-Body Supply) that could mix up anything you wanted and put it in a spray bomb for you. Can't hurt to call ones local to you.I saw a post from a couple years ago of a place that would put QQ1 paint in a rattle can but now their site only says they do motorcycle stuff. Color Rite I think….anywhere else that will do that? I just want to creat that factory overspray look back in the trunk after my surface rust removal and protection.
You are a lucky man. May be you should go out and buy a lottery ticket. LOLTried playing stripper music but she won’t do it on her own.
So far so good or lucky as far as rust goes. Both front and rear window sills are solid.
A few shots of fenders and front ends of rockers are good. A little surface but the plugs are solidly in place.
Thanks but not really for a retired a guy. Been taking care of a family member quite a bit. Got the rear axle assembly out. Hopefully K member and suspension tomorrow.Hey man, that's progress!
Cley
