Man. Another thing - could the transmission mount be sagging and dragging the engine down?I do not and let me just tell you, I look constantly. On here, ebay, marketplace......
Anything's possible, but they normally have more room than that.Man. Another thing - could the transmission mount be sagging and dragging the engine down?
Do you know where it's located? Can't find it in the service manual. I know there's that bracket for the transmission to the block, but what about the rubber one?Anything's possible, but they normally have more room than that.
It is between the cross member and transmission tail shaft housing.Do you know where it's located? Can't find it in the service manual. I know there's that bracket for the transmission to the block, but what about the rubber one?
yeah, it's in pieces. Probably contributes to the rubbing against the steering linkage.It is between the cross member and transmission tail shaft housing.
It's possible, I suppose, but it'll have nothing to do with it rubbing on the k frame. If you can weld, I'd just modify the front of the pan. Be a lot easier than finding an early a body pan.yeah, it's in pieces. Probably contributes to the rubbing against the steering linkage.
I assume a '62 B and A slant pans are no doubt different?? Just wonderingI do not and let me just tell you, I look constantly. On here, ebay, marketplace......
