........................Great score.........u have been a busy man and ur wife helping is just fabo lus.....kim......
while installing the new engine/lighting harness I found a heat shield. I have never seen one before and it appears it is to protect exhaust heat from the brake proportioning valve. It must be a 383 thing but even with that I have had a few in the past that didn't have this..? factory or home made? i cleaned it up, painted and re-installed it.
It was factory installed on 383 cars. Most seem to have been removed.
Accurate repops them.
This is pic of one installed.
Nice score! That paint looks a little to good to be using the car as a work bench are you going to repaint it?
Thanks, that one looks a bit easier to get too! =) Quote]
Probably why once they were removed for whatever reason they just got trashed. I would suspect the 69 440 cars had them as well.
Nice find by the way!!!!
Hey what paint did you use for that dash cluster? I'll be having to do mine here soon and yours looks good!
the frame was blasted and powder coated, with a no glare black almost a semi-flat and has a slight texture.
can - duplicolor chrome on the bezel
can - semi flat on the black parts
I had an argent made a touch darker then factory mixed and put into a can. I had to buy 6 cans and had a little left for airbrushing. I just started on my last can, but mopar argent would work also. I like the darker as it doesn't look dirty so easily.
I wipe with wax and grease remover then use 400 for any rough areas then a red scotchbrite pad to lightly scuff the rest.
I spray light coats and give a couple days after applying the chrome to the whole bezel first. then a day for each additional color. Do it in a warm area maybe with a heat lamp nearby.
I do not use primer or adhesion promoter and one that I did 2 years ago has no issues at all.
it does not have that real "chrome" vacuume metalized look, but it looks clean and tidy and has a duller chrome reflective quality. Not much of the "chrome" is really visible once installed. I use a thin brush and q-tip for the fine details details.
Hope this helps...
Hope this helps...
There's a guy not far from me that's getting one of those "Spray-Chrome" setups soon. I talked to him about doing the dash bezels for my Dart. He says he can do them, and it'll be MUCH cheaper than the vacuum metallizing procedure. I have a "junk" bezel I was going to give him, early in the new year, to try his system on before I give him my "good" set to do!
I'll keep y'all posted on the results.
