famous bob
mopar misfit
having had both a hemi b body, and a 440 b body, the hemi would do it every time. and the other guys 6 pack wouldn`t beat it either! been there done that-----bob440 up to 100mph, all hemi after that then bye bye 440.
WRONG
Virgil had a 67 GTX with a Factory HEMI
The only engine option in the GTX was a HEMI
The 440 six pack would outrun a Hemi on the street in street trim, a 4 bar car would have a hard time, the traction would be the biggest problem and as others have said the 440 would probably get the Hemi out of the hole but the Hemi would pass it on the top end.
Too bad the 440 6bbl didn't come out for another 2 1/2 yrs. Again, in 1967 the GTX came with one 440. 375hp Super commando. The HEMI, obviously, is not a 440.
The only 440 available in the 67 GTX. Super commando.
Detroit Magazine 'Autorama' Performance Tests
4-Speed ~ Dana-Rear ~ w/3.54 Gears
Inland Shifter and 7.75 x 14" 'Red-Streak 'Tires
1967 Charger R/T '426 Street Hemi' .................. 13.89 @ 102.65 MPH
1967 GTX '440 Super Commando' ...................... 14.08 @ 100.84 MPH
Then please explain where my statement was wrong.
Damned old shifters...lol..I remember them,lots of races lost due to 'shifter' problems..but hey thats racing...run what you brung1967 Plymouth GTX ~ '440 Super Commando'
Equipped with a 4-Speed Transmission, and a Dana-Rear w/3.54 Gears
'Super Stock and Drag Illustrated'
New Car Performance Test "Part 1"
The Plymouth Dealership out on Long Island {Hempstead Chrysler-Plymouth} installed for us,
a set of 'under-chassis' Hooker Headers.
And we brought along set 8.00" x 15" Cheater-Slicks mounted on a set of new 'Keystone' Wheels.
Westhampton Drag Strip out on Long Island.
Driver - Eddie Romano
After a quick timing check, and removal of the Air Filter element. And with 'closed' Headers running
thru the stock exhaust system, Eddie took the GTX to the starting line equipped with the 8"-Wide
asphalt grabbing 'Prowler Slicks' filled with 20 lbs. of Air-Pressure.
On Eddie's 1st-Attempt, he lit the 'slicks-up' coming out off the Line, and pulled up before he even shifted
into 2nd-Gear.
In the 2nd-Attempt, Eddie came off the line much better, but he couldn't get the shifter mechanism
cleanly into 2nd-Gear. Eddie again pulled up and cruised thru the traps at 70 MPH.
In the 3rd-Attempt, Eddie was finally able to get the GTX down the track, but still not without gear-shifting
problems, as the GTX pulled a 14.32 @ 100.19 MPH.
In the 4th-Attempt, Eddie ran into problems slamming the shifter from 2nd-to-3rd Gear, as the GTX
barreled the track where Eddie put down a 14.47 @ 98.75 MPH despite significant shifting problems.
After the '4th-Time' down the '1/4 Mile', Eddie was begging the Plymouth Representative to pull out
the Console and rip out the 'Inland Shifter'.
