Is it hitting the bottom of the pan when fully inserted?Got it 5 quarts. I actually have the short filter but I’m gonna put 5 quarts in.
When shortening the dipstick do you trim the top?
NoIs it hitting the bottom of the pan when fully inserted?
You shouldn't need to cut it then.
Exactly. Something is goofy for sure. Shortened tube, wrong tube, or the wrong dipstick. 5 quarts with a filter, run it and shut it off. Let it set and then recalibrate the dipstick.You shouldn't need to cut it then.
Have you measured your tube?
