Crazy Cuda. Sherwin Williams has a handy on line color tool. Under "color tools" select Custom Restoration Color Programs, then select Rod and CustomWhat color is your motor? I like it.
My guess is he probably installed the engine, ps box and headers all on the k-member outside of the car, then installed it all into the car all as one unit from underneath.Thanks Matt, was just revisiting their wares. Moparhead has same car, p/s too, and same headers with pics of everything installed. Maybe he can shed some light.
Man, if so that could make a gasket change a big deal, unless the entire gasket slips out clean. Im getting more interested in the smaller aftermarket p/s boxesMy guess is he probably installed the engine, ps box and headers all on the k-member outside of the car, then installed it all into the car all as one unit from underneath.
Thanks Matt. Reading through Forums, I can try raising the engine, possibly taller mounts. Do you happen to know if a Borgeson alone will fit?Or you could put in a 16.1 manual box, and hide a Toyota Yaris EPAS (electric power assisted steering) setup under the dash. Theres several threads on this. It's not direct bolt in, and does require some close tolerance machining work.
With box in, I'm not even close to getting header positioned. I can raise car more, I'm reading that helps. Box definitely not going in with headers mounted.No I dont have the answer to that. Is your stock box hitting headers? Most likely the borgeson box alone will correct that. I dont know how much clearance issues you have that raising the engine will correct.
I haven't ordered it yet, I see Summit has them and a couple other places. Pricing seems to be samelooking good. where'd you order the borgeson box from?
which i would take in a second
Right On thanks a ton!check with @GMachineDartGT, he's Bergman Auto Craft and can set you up
Not bad, I wish the 2014 turn signals were not housed together with headlights!just for fun, I took out the inner lights and put 64/65 Valiant turn lenses on it in the lower valance
That's a good look. Using black cardboard ive mocked up different " covers " for these marker lights, nothing jumping out at me yet. Thought about a flat clear maybe to diffuse them. Here's current. I think looks good head on, at an angle the 4 eye look starts to become more apparent though.just for fun, I took out the inner lights and put 64/65 Valiant turn lenses on it in the lower valance
you are obviously very good at making things work, there's no way you can cut the marker bezels out? I don't hate the "4 eye" look at all, but the car seems too small for it.. it puts everything too close. What about smaller amber lights in there?That's a good look. Using black cardboard ive mocked up different " covers " for these marker lights, nothing jumping out at me yet. Thought about a flat clear maybe to diffuse them. Here's current. I think looks good head on, at an angle the 4 eye look starts to become more apparent though.
To answer your question, the marker light and head light are all once piece in a sealed housing. If I were to eliminate the marker, I'd just fiberglass the grille opening shut.you are obviously very good at making things work, there's no way you can cut the marker bezels out? I don't hate the "4 eye" look at all, but the car seems too small for it.. it puts everything too close. What about smaller amber lights in there?
