1968 Dodge Dart
as of yesterday.....25 years for HemiDenny (always the show-off)
it's driving season, now about an update?
Some how I dropped a cylinder, #1 is not firing. It has spark, fuel, wires are good, cap and rotor is good, injector checks out good, compression is 165 so that's good. Today I am going to do a leak down test. I will also check the valve spring, push rods. just my luck!
i've had bad caps and rotors that look fine on more than one occasion. they're both cheap enough to try before you spend too much (time and money).
neil.
I like how you think. I did a leak down test tonight and it was at 7%
I’m thinking cam is good
First drive. Went pretty good
