HemiMark
Tod is doing great. He will keep me in line with all the wiring, you know red to red black to black.looking good Mark. When i saw the line-lock and that pretty paint, three words popped into my head. synthetic brake fluid.
hows the Wheelie King doing?....he looks right at home.
I’ll look again. Thanks Dennythe four powder coated black upper shock spacers were in a small Qa1 ball joint box....along with the cotter pins for the ball joints. Ill send you 4 more....if needed.
on the fifth picture (down) posted above....I think I see the above mentioned (white / red) Qa1 box on the second shelf down...right above the stacks.
fire in the hole?.....itsn't that usually followed by a giant BOOM?
Are you being serious about the synthetic brake fluid? I benched blead the master with Dot 3 but if you think synthetic is the way to go I order a new master. Let me know.
I will for sure. I'll call yoou soon!you will be happy, it will keep your nuggies from sucking up to your throat when you see a drop of escaped fluid......friendly reminder, doublecheck and re-tighten ALL your connections before you start to bleed.
Off to a friends shop for the SS exhaust. Looks great in the sun!
