= no leaks!!!!!Nice! Double clamped coolant line?
Your engine compartment sure looks purty!
I've had overheated connections at the firewall connectors and at the headlight switch on 2 Cuda's. Other Mopar owners have had the same thing, including fires. I don't want any fire risk after doing this restoration!!! I've bypassed the ammeter (converted to a voltmeter) and connected the 8 Ga wire direct to the starter relay. This prevents battery charging amps from flowing through the bulkhead connector.Love the detail!!! Brake line correctness for the period!
I know why you did the HL relays but are they really needed?
A side benefit is far brighter headlights.
Check this outdid you send your ammeter out to get converted to a voltmeter? or do you have a write up on how that is done?
thanks
Looks beautiful, if you don't mind me asking how much did it cost for this gauge restoration.I sent my cluster to Redline Gauge Works for restoration and the ammeter conversion to a voltmeter. Home - Redline Gauge Works
I had a lot of work done on the cluster:Looks beautiful, if you don't mind me asking how much did it cost for this gauge restoration.
