I’ve been very impressed with the quality of their restorations and will use them again. Just need to make sure we both understand what might be replaced.
Yup - dash assembly will soon start. Currently working on getting the engine and tranny mated.After firewall insulation goes in, the parking brake is probably next. Followed by the heater box, and LH vent box, then the brake pedal, and gas pedal, dash goes in last.
if you ever need to disconnect the wires from the starter with everything in the car you might wish you left that onWas installing the tranny and a mini starter today. I bought a terminal extender kit to move the connection points for easier installation. BUT, this extension kit does nothing to help the connections!!! It may work OK on a big block tranny, but I wasted my money on buying it for a small block!!!
Thx for the feedbackif you ever need to disconnect the wires from the starter with everything in the car you might wish you left that on
car is looking fantastic
It is not very heavy. I used approx 2 packs which is 30 lbs total. Dave Rea, one of the top Mopar restorers uses it on his restorations unless customers dont want it.beautiful. thanks for all the detail.
just wondering.....Dynomat weighs a ton. Would you use it again or opt for a lighter product? For what it is worth, I used the heavy Dynomat on my silver duster over the floor exhaust area, but opted for the lighter stuff where there was no heat. I have throttled back on any of it in recent builds, if I drive similar cars with and without it....no noticeable difference except a lighter wallet.
I will add a layer of 1/4” closed cell foam on top for sound absorption. This combination of damping and absorption that has the biggest effect
