1969 Barracuda 340 Formula S Restoration
Drivers door internals installed. Good thing I had taken disassembly photos showing where these rods connected to the door latch mechanism!!!
Thanks! Nice detail pics.
I have my outside handles and locks figured out.
Your pics will help a lot with the inside door handle linkage orientation!
I have the service manual but those illustrations are usually tough to follow at best...
Last step was to spray some rustproofing in the pinch weld seam. Lots of different products, but this is the one I use.
Before you button it up, after you adjust the striker position be sure to adjust the latch. Most folks are not aware of this adjustment.
Door Latch Adjustment - 1968 Barracuda
Agree that this can be an important adjustment. After assembling the passenger door, the door lock did not work to lock the door. Made a small adjustment and now it works!!
