1969 dart rebuild !
The alt. I have on is a 70 amp and I have a 120 amp waiting in the wings just incase I go with an electric fan.
The tires on there are just to get me going....testing tuning. I will get wider rims and tires when the time comes.
Lookin great, I'll be following your progress!
Got the brakes and hydraulic tb bled along with getting the car back on the ground.
They are AMD panels and come that way.
After the mini tub, my gas struts for the trunk will no longer function as they did before so I put the torsion rods back in place.
Getting the fuel cell mounted along with the gas fillers. One on each side so it won't matter which side is open at the gas station.
Steering column is mounted.
Tail lights and bumper are on, getting ready for maiden voyage Saturday.
Thanks. I'm just gonna go around the block a few times and see how it does.
Fixed a rusty area on the quarter panel.
Maiden voyage took place today. I just went around the block a few times. I have a video, but not sure how to post it. Also barked the tires in the driveway.
Drivers door installed today.
Patch panel on the trans hump was made and welded in. I'm using an b/e trans with the adapter to put the shifter in the stock a body location and I needed a bit more room. Also put in 3/4 inch spacers under the front seats, made the seating position so much better for me.
Got it outside so I can adjust the pass. side door.
Flush mounted gas filler neck is welded in.
