1969 dart rebuild !
I scored mine off eBay, so it was CHEAP. This is what I’m using. Derale PWM Electric Fan Powerpacks 66833. It works great! I would get the updated temp sender, it sticks to the bottom radiator tank. You can get the 4K version, but my 472 is cooling just fine at 3750. The dimensions listed are what you should go by with your inside dimensions on your radiator core.
A bit more work on the dash netted me the hvac vents for the top and cut out for the stereo. Still need to drill a hole for the wiper switch and cut an opening for the Vintage Air Gen IV controller.
I painted the dash Jet Black and adjusted the air pressure to give me a slight texture. Then I used a Matte clear.
The ash tray cover and glove box door are in high build primer and should finish those in the next day or so.
Dash is in the car and surprisingly everything works!
Just to get me buy, Duplicolor. When I tear the car down for body paint, it’ll get blasted off and use some better stuff.
