Took my wife for a quick ride....................It is so awesome to be able to drive the car together after 50+ years!! I know my FIL was riding along.....................
Just ask him not to look in the back seat this timeTook my wife for a quick ride....................It is so awesome to be able to drive the car together after 50+ years!! I know my FIL was riding along.....................
I have the overflow bottle mounted, I need to get the correct size hose. Would you happen to know the correct size?you might want to put a drain hose on the radiator overflow fitting and route it pointing to the the ground. If it happens to build pressure and releases, it will be spraying all over your pretty Hemi.
Thanks Dave.I just use 1/4 inch fuel line.
1/4" vent hose, not as thick as fuel line. and doesn't need to be because there is no pressure on it. A tension clamp is a good idea on both endsI have the overflow bottle mounted, I need to get the correct size hose. Would you happen to know the correct size?
Crazy how stiff the throttle pedal is, the heavy clutch too. What an experience!
Thank you! I Love it!!Certainly a man’s car! When I had a 4 speed in mine with a heavy clutch and a vertigate it was pretty wild to drive. Car looks great brother!! You’ll enjoy the hell out of it.
Dart looks great. Been a fan of the 4-speeds for over 5 decades. Having an automatic in a hot rod like the Dart is like sex with a condom. You get there....just not as much fun.
Neither of the headlights are working, I need to mess around with the wiring.Your driver's side headlight bulb looks dead in that photo.
Well, that one's going to need a bulb tooNeither of the headlights are working, I need to mess around with the wiring.
Thanks, I think I will get a new set...............Well, that one's going to need a bulb too
Bob, any issue with the new bulbs and old charging system, etc.? ThanksWell, that one's going to need a bulb too
Thanks already replaced the harness. Guess I just need some new lights.If head light wiring old worn out Year One sells new M&H wire harnesses which are identical to the originals. Just unplug old harness at firewall and plug new harness in.
Haven't had much dry here for a while. I am out of town next week and then loading it up for Mopars in the park. Looking forward to the first show having the car and telling the story.So when roads are dry you take it out for some drives?
