Thanks, I see now that I did not place the bottom spring right. on the left side. The top bolt on the shock with the rubber bushings, How hard do I tight that one? I could go on until there are no more threads on it and the bushings are really squished.Yikes!!!!
From zero to hero on 1 quick order!
Nice!
Took my girlfriend on a road trip today. Only small country roads. We checked out three different castles and had dinner in the archipelago. The car drives great, it goes totally straight on the road, the temp gauge is nice and steady, breaks are nice and even and it is really nice with the new shocks up front and the new leaf springs out back. Gas mileage is 1.78 liters for 10 kilometers. I'm not sure how to convert it for you guys. A great day!
Otherwise, I love what's going on with it! You're doing great work and look forward to every time I open this thread. I'll finally get to go pick up my Scamp from my dad's place pretty soon. I just recently moved into a new house and I had a 30'x40' slab poured. The 30'x40'x12' structure kit should be delivered this week, and hopefully erected in a week or so. I'll only have a single 10' roll up and 3'x7' man door, but it'll work for what I'm doing, I think. It'll probably be a while before I get electric set up, but I want it to be equipped with an 80 gal compressor, availability for a good quality welder, and eventually a 2 post lift. I found some 4' (1.2m) LED lights on Amazon that come in 4 packs for 120USD and I'll probably have about 8 or 12 of them.
I've missed out on 4 years of actually being able to work on my projects due to change of duty station assignments in the USAF, now I'm retired from active duty and shouldn't have to move any more, so I can lay down some roots again and start resuming parts and activities in my life that have been placed on hold.
What brand sound deadener did you use?New paint and woodgrain sticker for the cluster
New paint for the grille too
Cleaned and painted the floor
Installed sound/resonance deadening material. Not too pretty, but no one is gonna see it
Looks good, but shouldn't there be a lever on the star wheel.I got new brake shoes and shocks for the front from RockAuto. Had time to install the drivers side today. Doing the rest tomorrow.
New shoes and the Monro-Matic Plus
The old ones
Installed
View attachment 1715079185 View attachment 1715079186
There is a lever on the rear breaks, but not up front.Looks good, but shouldn't there be a lever on the star wheel.
Isn't the 625 carb a little on the small side? Wouldn't a 750 - or bigger - be 'better'?The 360 will go together something like this
Stock crank, rods & bore (honed by me)
All new bearings & oil pump
Ported (by me) 3769974 heads - Mr. Gasket 1121G
Speed Pro H116CP pistons
Compression Ratio : 10.05 : 1 (according to a calculator)
Xe268H and matching springs, new lifters, chain and gears, stock rocker assembly
LD 340 Intake
Street Demon 625 carb
PerTronix Ignitor II Billet distributer & Flame Thrower coil
Long tube headers
2.5" Dual Exhaust / Super 44 Flowmaster
8 3/4 with 3.55 or 3.73 and suregrip
3000 stall converter
275/60-14 rear tires
I might be, but it is what I have right now so I'm giving it a tryIsn't the 625 carb a little on the small side? Wouldn't a 750 - or bigger - be 'better'?
I might be changing my AFB 750 for an AVS 750 that I've renovated. That'll make the AFB for sale.I might be, but it is what I have right now so I'm giving it a try
I had a change of plans again. Just ordered my first set of Edelbrock RPM heads
So are you selling the home-ported 360 heads? I'm interested!I had a change of plans again. Just ordered my first set of Edelbrock RPM heads
I had not thought about that just yet. But sure. I would be happy if they get used. I have new exhaust valves for them. I was going to replace at least 2 guides, but they should probably all be replaced or knurled. They are in Stockholm/Farsta if you wanna have a look.So are you selling the home-ported 360 heads? I'm interested!
Sweet! I'll PM you so we can hook up somehow.I had not thought about that just yet. But sure. I would be happy if they get used. I have new exhaust valves for them. I was going to replace at least 2 guides, but they should probably all be replaced or knurled. They are in Stockholm/Farsta if you wanna have a look.
