wade
awesome danny. even if your doing major stuff and need a hand give me a shout
awesome danny. Even if your doing major stuff and need a hand give me a shout
Gonna section in wheel tubs? Or change the whole half.
Great progress! I couldn't help but chuckle after seeing the ralley wheel in the rack with snow tire on it. Seen many of those on A bodies in my time.
Danny! Boy, when the full back 1/4 is off, it looks daunting - glad you know what your doing!!! Keep 'er swingin' buddy.
Great work!
What is it with you guys in Northern Alberta with the quick work and skill on panel replacement? lol
Keep it up, i'm lovin' every minute of it........
That's looking really good! I did have troubles with my door to quarter fitment. The gaps were good on the drivers side but the quarter was to curved outward compared to the door.
Here is where mine was out.. Where all the E-coat is scratched off is where I had to flatten the quarter panel out to match the door. Once I did that the bodylines lined up. I have a giant C clamp you can borrow if needed. I just plug welded it from the bottom up squeezing the quarter into the B pillar as I went which in turn made the quarter longer which was needed... My passenger quarter was a bigger nightmare! I hope yours fits good.
Thanks for the tips Randy, sounds like our fitment problems were similar, mine has a slight bulge in the same spot and the flange on mine hits the inside of the B pillar right at that spot so it won't push in so I'll have to grind some of the edge of the flange off so the panel can flatten and hopefully move upward. I know when I pulled the bottom down and over the rocker and clamped it obviously made the problem a bit worse. The door needed a slight adjustment before I removed the quarter but line up nicely, I think I've got slightly more gap then I have and moving the quarter ahead a touch seams to be a bit challenging. Squeezing it upward is what I need to try.
Beautiful project! And I love your caster system! I've been thinking a lot about my project and how to get my car off the floor and I think this will be a perfect solution. Mind if I rip it?
let me know how they work for you.
