1973 Dart Swinger cooling
Heating / Cooling / AC
  1. erafuse
    erafuse Well-Known Member
    132
    32
    Jan 30, 2013
    PEI,Canada
    Local Time:
    11:47 PM
    Have a 1973 Dart Swinger stock 318 2v Auto. 63,000 original miles. Radiator was recored ( looks small 19” but it’s orginal ) runs fine on the highway in traffic on a hot day gauge goes up to half way(not sure of actual temperature).Has not boiled or anything. Like for it to run a little cooler in traffic. Would a fan clutch help or a cooling fan ? Any info would be helpful thanks.
  2. Streetsboro Rick
    Streetsboro Rick Well-Known Member
    164
    67
    Apr 27, 2018
    Streetsboro Ohio
    Local Time:
    12:47 AM
    Start with a shroud should help
    • Agree Agree x 1
    • erafuse
      132
      32
      Jan 30, 2013
      PEI,Canada
      Local Time:
      11:47 PM
      Thanks. Any idea where to buy a shroud for a 19” radiator?
    • Streetsboro Rick
      164
      67
      Apr 27, 2018
      Streetsboro Ohio
      Local Time:
      12:47 AM
      Some one on this site might have one put a wanted ad up
    • 383Scampman
      383Scampman Well-Known Member
      1,666
      879
      Nov 24, 2013
      New Hampshire
      Local Time:
      12:47 AM
      First off , you should have a 17 1/2"x22"x1 3/4" radiator . If that is the case , Classic Industries has a shroud for that rad . Secondly , make sure the rest of your cooling system is up to the task . thoroughly clean the block and heater core . The shroud should do the trick . If it doesn't , install a clutch fan . You shouldn't have an issue after that . But just in case , you can go with a 160*F thermostat if it still runs hot . Make sure you have 50/50 coolant and DISTILLED water . When and if it's still hot let us know again and we will solve your issue . Good luck , Tom
    • erafuse
      132
      32
      Jan 30, 2013
      PEI,Canada
      Local Time:
      11:47 PM
      Thanks.
    • erafuse
      132
      32
      Jan 30, 2013
      PEI,Canada
      Local Time:
      11:47 PM
      Thanks. The radiator is only 19” wide not 22”. When I had it recored they said it was original. Do you know if you can buy a shroud for a 19” radiator?
    • TF360
      TF360 Well-Known Member
      1,724
      540
      Apr 25, 2014
      Florida
      Local Time:
      12:47 AM
      I would go with the bigger radiator and of course a shroud that came in those cars. I owned a 318 and it had the bigger one. I would question weather that is original. Usually only the slants came with that one. 180 degree thermostat. Also, get a aftermarket gauge. It provides a little insurance
    • fklskv
      fklskv Well-Known Member
      1,183
      626
      Aug 14, 2011
      Lackawanna, NY
      Local Time:
      12:47 AM
      Halfway on the gauge with no boil over seems like nothing to worry about.
      • Agree Agree x 1
      • toolmanmike
        toolmanmike FABO MODERATOR Staff Member FABO Gold Member
        52,771
        38280
        Jan 18, 2006
        Iowa
        Local Time:
        11:47 PM
        How do the shrouds attach? Anyone have pics?
      • erafuse
        132
        32
        Jan 30, 2013
        PEI,Canada
        Local Time:
        11:47 PM
        Okay. Just wanted to be safe.Thanks.
      • Streetsboro Rick
        164
        67
        Apr 27, 2018
        Streetsboro Ohio
        Local Time:
        12:47 AM
        Still could be original rad they didn't care in the 70s they installed whatever they were given shroud should attach to the sides of the rad
      • j par
        j par Well-hung Member
        24,616
        12921
        Jul 2, 2014
        Portland Oregon
        Local Time:
        9:47 PM
        Stop the speculation. Buy a heat gun and verify or borrow one.
        • Agree Agree x 1
        • H22A4
          H22A4 Does anyone read this?
          2,070
          983
          Aug 4, 2006
          YVR
          Local Time:
          9:47 PM
          Despite what some folks are indicating the 19” rad in your car is what it came with from the factory. If your 318 had AC or was ordered with the heavy duty cooling option, it would have had a 22” rad. Also in 1973 the A bodies were available with a 26” rad for the first time. Prior to that all A bodies came with a 19” or 22” rad. The rad core support is different between the 22” and 26” radiators so if you upgrade to the 26” it will require some drilling to your existing core support.
          As some other have suggested, get a shroud for your 19” and you’ll probably see an improvement.
        • erafuse
          132
          32
          Jan 30, 2013
          PEI,Canada
          Local Time:
          11:47 PM
          Thanks for the info. Does not have air conditioning and not ordered with heavy duty cooling. Bought from the original owner 3 years ago 59,000 miles when I bought it and it seems the 19” radiator came with the car new. The radiator shop that recored it thought it was the original anti freeze. Going to try a shroud if I can find one.
        • Streetsboro Rick
          164
          67
          Apr 27, 2018
          Streetsboro Ohio
          Local Time:
          12:47 AM
          As I have said before the wealth of knowledge on this forum is mind boggling if someone here doesn't have the answer then I doesn't exist
        • erafuse
          132
          32
          Jan 30, 2013
          PEI,Canada
          Local Time:
          11:47 PM
          Yep lots of good info. Always someone willing to help.
        • erafuse
          132
          32
          Jan 30, 2013
          PEI,Canada
          Local Time:
          11:47 PM
          My wife has one she uses for cooking pizza. Will borrow that one. Lol
        • fklskv
          1,183
          626
          Aug 14, 2011
          Lackawanna, NY
          Local Time:
          12:47 AM
          Your wife cooks?!!
        • Ccas
          Ccas FABO Vendor FABO Vendor
          224
          158
          Dec 7, 2016
          Hatfield, PA
          Local Time:
          12:47 AM
          Based one your analysis of the situation, it just sounds like you need some better air flow when sitting in traffic.
          That radiator sure looks stock to me. The fan looks big enough. One thing you could try is just adding a spacer to the fan to get it a little closer to the rad. It looks a good 3-4" away from the core?
          If an OEM shroud is not available for that model, you could have one fabricated out of aluminum. I've also seen universal shroud kits that aren't that expensive and should help pull more air through.
          Lastly, while I cringe when anyone considers putting an electric pusher fan on a radiator (not very efficient and will block air flow on hwy), that solution is not all that bad if you have space in front of your radiator. I have seen hundreds of cars use a pusher fan successfully despite it being a band-aid fix.
        • erafuse
          132
          32
          Jan 30, 2013
          PEI,Canada
          Local Time:
          11:47 PM
          Yep. One of the best Even comes to car shows with me !
          • Like Like x 1
          • erafuse
            132
            32
            Jan 30, 2013
            PEI,Canada
            Local Time:
            11:47 PM
            Thanks. Yea I thought about a cooling fan but since it’s an original car would like to keep it original looking. Might try the spacer and a shroud if I can find one.
          • Jimacuda
            Jimacuda Well-Known Member
            1,862
            623
            Nov 10, 2006
            Phoenix AZ
            Local Time:
            9:47 PM
            Until you can put a real number to the temperature its just guessing.
            Mechanical temp gauges are inexpensive.
            Not boiling over is a good indicator of not having a problem, or not a serious one.
            • Agree Agree x 1
            • erafuse
              132
              32
              Jan 30, 2013
              PEI,Canada
              Local Time:
              11:47 PM
              Thanks when I bought the car it would run up to 3/4 on the gauge so put a new sending unit in and recored the radiator and it does run cooler. Due some city driving and parades so just being cautious to try and keep temperature down.
            • erafuse
              132
              32
              Jan 30, 2013
              PEI,Canada
              Local Time:
              11:47 PM
              Is the Mopar part # for a 1973 Dart shroud 3691916 ? Also would a clutch fan help to keep temperature down?
