1974 D100 frame off build up
I am doing things properly to keep spring rates right in the rear, I won't need to notch my frame as I won't be loading weight in the bed. After some more research I may be able to weld in the threaded rings for K772 ball joint into the van lower control arms as an option if I want to keep stock front coil springs. But with the MII LCA I can run coil overs from QA1 or something similar. The MII spindle using the MII bearing is also fine, there is a $800 kit for Wildwood disc brakes and calipers for the stock style spindle. I want to demonstrate something new, this isn't just about taken the beaten path for my own needs. I made a small business making gauge panels for these trucks because I made my own path I want to expand my contribution to the Mopar world by doing something no one else is doing. And the more pushback I get the better!
I believe it’s CPP that makes a C5 hub and sealed bearing for the mustang II spindle.
Correct, that's who I was looking at. The only downside is needing 17" wheels. But it's an option, Corvette brakes are very light weight, and an affordable way to get a big brake kit. I think I will go with the MII bearing style and get the Wildwood 11 inch brake kit from summit racing for my build, but I would like to gather all the parts for a tangeable demonstration! It could open up a new door for options for those looking for more. Also I like that you can option all of this to use the 5x4.5 bolt pattern, or the 5x5.5
Well, $961. And a wilwood rear kit for the next rear axle is available as well. I have plans for the universal wilwood booster and master cylinder with a proportion valve. The entire brake system is being rebuilt from scratch, on an upcoming video
I lost the shop. But I also got a new shop. I dont know what can and cant be done at this moment. Here's the update video, and Im selling a toolbox, its at the end of the video.
I believe I forgotten to post here on the update. But Ill keep it short! I got the front chassis off a wrecked truck and I can start making a Jig for making control arms to work with those Mustang 2 drop spindles. I have to use Wilwood pro spindles unless I find another MII spindle with a bolt on steering arm. I havent put a lot of effort into looking for any yet. I have to extend the steering arm out a few inches to match the D100/D150 steering arm. Another Idea would be to figure out a rack n pinion gear for this kit, and If I do, I will always have updates on my progress! As of now I have a chassis jig, I have cheap drop spindles to use as part of the jig when making control arms, and I have some custom made hub adapters I made for doing the early and late wheel bolt patterns. Still need to get brake rotors and bearings, Balljoints and threaded adapters, and a cheap coil over kit so that I can remove the spring and test suspension articulation
Got an update on my side project. The jig was completed, and I have a rough draft of control arms for Wilwood MII pro spindles and brake kit. Im still gathering things to bring about a final part in my hands, and I got a couple of Cummins powered trucks to thrash on with these for strength testing. The only part I dont have a solid answer for yet are the coil overs, I have 750 lb springs on QA1 coil overs for GM vehicles in mind, and I think the placement of the lower mount on the lower control arm is what I need to dial in, and possibly make adjustable depending on the front axle weight of each truck. I may be able to figure in a rack n pinion setup as well, and if I do, It will be on youtube, and here.
Im getting somewhere with these control arms. And I am very unqualified to be using a CNC plasma cutter lol
