Set that TV correctly. Wide open throttle, the TV should be all the way back. I've had leakage problems on mine the last couple years. Had to rebuild it last year due to leaking through the vent, worn clutches, etc. Still have a bit of leakage this year. going to try a catch can. I beat the hell out of that tranny for years. Burnouts, rolling burnouts, street racing, track racing, etc... I like it. I'd like it more if I could figure out the leak though. I'd definitely do it again. I can cruise the highway at 80 mph and 3000 rpm now with 4.10 gears and 28" tires.
Yes the TV cable is probably the most important thing to have adjusted correctly on these. I should be running 2500 rpm @ 81 mph with 4.10 gear and 30” tires. Can’t wait!
