j par
Well-hung Member
I understand you trying to make your car drivable, but 12's need a little something...
this wouldn't be my first rodeo...… I'm guessing I'm already mid 13's with 2.76's and a stock 360. 3.23's and magnum heads would put it there, you know that, right? At least my figuringI understand you trying to make your car drivable, but 12's need a little something...
that add says 2018 ???318 Did you see the Belvidere Show is this week end?
Belvidere Mopar Happening Car Show & Swap | Chicagoland MOPAR Club
YOUR LATE!!that add says 2018 ???
Heads and gears, sounds easy....this wouldn't be my first rodeo...… I'm guessing I'm already mid 13's with 2.76's and a stock 360. 3.23's and magnum heads would put it there, you know that, right? At least my figuring
Well, I have the magnum heads and my home ported 596's. Both would keep the car running as smooth and polite mannered as it is now. 3.23's is still a nice street gear, especially with a stock converter.Heads and gears, sounds easy....
you going?
yeah, heat index 115. Wow! I just mentioned it to my son... we'll see. the heat is a killer for me.I just found out about it a few minites ago.
I was planning to go pickup that 67 dart in chicago this weekend.
I need to see if I can do both on saturday.
The 100 degree weather will be part of the deal also.
I'm not saying you haven't been there or done that. I remember everything doesn't add up to something big each time. Like two tenths for this two tenths for that and for the other. Sometimes it just doesn't stack up that way...Well, I have the magnum heads and my home ported 596's. Both would keep the car running as smooth and polite mannered as it is now. 3.23's is still a nice street gear, especially with a stock converter.
Agreed, but no power to put on the ground loses races as well...
Just waiting and watching.
I have no doubt both of ya can make a car run, i just want to see the result.
I will stand on the fact that cash spent dont always win. 318 on budget may beat Jab best of the best.
HP aint the end all be all. Power to the ground wins races.
For instance I've been looking at some stockish aluminum heads and they may not make one bit of difference, but everybody says aluminum heads should be worth two tenths?I'm not saying you haven't been there or done that. I remember everything doesn't add up to something big each time. Like two tenths for this two tenths for that and for the other. Sometimes it just doesn't stack up that way...
Well, lets just say I hit a 13.50 now. I will say 2 tenths for a 1/2 turn of the drive shaft is more than a reasonable expectation (2.76 to 3.23's). I know I can get 3 tenths from heads. That, my friend, would be a 12.99 on a good pass. What about if I gain a little more, and my car is already a 13.40 ? Now you are looking at 12.8's ??I'm not saying you haven't been there or done that. I remember everything doesn't add up to something big each time. Like two tenths for this two tenths for that and for the other. Sometimes it just doesn't stack up that way...
Well I gave you I like for your optimism LOL number one and this is a big number 1 LOL you have not yet done a 13-5!? LOL so let's not already put you there as a base LOL that could be a 13-7? And your other figures could be off by a tenth or so as well the other way LOL and now what do we have...Well, lets just say I hit a 13.50 now. I will say 2 tenths for a 1/2 turn of the drive shaft is more than a reasonable expectation (2.76 to 3.23's). I know I can get 3 tenths from heads. That, my friend, would be a 12.99 on a good pass. What about if I gain a little more, and my car is already a 13.40 ? Now you are looking at 12.8's ??
my butt dyno is pretty accurate.... I trust it! LOL Sure, it's all hypothetical. I miss chat so bad. We all could be there jawin' away.....Well I gave you I like for your optimism LOL number one and this is a big number 1 LOL you have not yet done a 13-5!? LOL so let's not already put you there as a base LOL that could be a 13-7? And your other figures could be off by a tenth or show as well the other way LOL and now or do we have...
So all your car analysis it's coming out of your butt dyno...?my butt dyno is pretty accurate.... I trust it! LOL Sure, it's all hypothetical. I miss chat so bad. We all could be there jawin' away.....
It hasn't returned to the strip since adding 2.76 gears and headers.So all your car analysis it's coming out of your butt dyno...?
- One measuring stick is a marked off distance (less than a 1/4 mile) on a back road I use to see if there is an increase in mph.
- Another is my "seat of the pants" feel...
no, that app isn't very accurate, and very inconsistent. I do use GPS to measure against my speedometer.Have you ever tried that drag race app when your out tuning. There was a thread a while ago about it. It could be another tool to calibrate the old butt dyno.
Translation= yes...It hasn't returned to the strip since adding 2.76 gears and headers.
There's only one app that works app-ly your vehicle to the quarter mile..no, that app isn't very accurate, and very inconsistent. I do use GPS to measure against my speedometer.
