Do you want enough for both cars or just one?
1 1/2 x 3 x 48 inches right?
1/8 thick?
1/8 thick?
sure, sounds goodDo you want enough for both cars or just one?
1/8 thick?
He could send it off today, right?Just donate the 40 bucks to " Toys for Tots "
What in the heck are you talkin about! You don't even have anything that does 8's in the 8th mile, let alone the quarter...8's in the 1320.…. about 160 mph... I was hoping Jaws wouldn't make me pull out anything heavy hittin'.... LOL
subframe connectors..... Ahhhhhhhhhhh …. good subject
.Just donate the 40 bucks to " Toys for Tots "
I said my brothers '64 Nova. Only sad thing, it's drag only....What in the heck are you talkin about! You don't even have anything that does 8's in the 8th mile, let alone the quarter...
On the contrary please make out your check payable to Shriners Hospital for kids...Just donate the 40 bucks to " Toys for Tots "
.I said my brothers '64 Nova. Only sad thing, it's drag only....
I finally got blinkers but the last time I was blasting up and down the on-ramp exit ramps on the freeway my windshield wiper on the passenger side went up almost three-quarters of the way LOL I've got to remember to attach them to something so that doesn't happen...
So fix the lights, put a license plate on it, put some Mufflers on it, drive it on the street.
Hey Cope does it.
.On the contrary please make out your check payable to Shriners Hospital for kids...
.I finally got blinkers but the last time I was blasting up and down the on-ramp exit ramps on the freeway my windshield wiper on the passenger side went up almost three-quarters of the way LOL I've got to remember to attach them to something so that doesn't happen..
I have all the rods all zip tied up underneath but I guess 'they're not holding the windshield wiper from floating up. I prefer not to have it at all but I recon they should be there...
That's what they made zip ties and duct tape for.
I may be wrong but from my research the new pins are not technically "pressed in" the rod is heated and expanded until the pins basically slides in with little to no effort. Then when the rod cools it shrinks then it is considered "pressed" into place I don't see how you could damage the piston in this way. Now the rod I could see getting it to hot and and damaging it. From what I understand in a professional setting the rods are control heated to a precise temperature not just freestyling it with a torch. Lol.
Interesting as in can you do it without destroying the piston.
The old piston doesn't matter if it gets damaged I have already tested it and I can get them out pretty easily with a ball joint press iv already removed 4 of the 8 they came out fairly quickly.As I've said in the past good luck with that.
I've seen The Little Oven. that the rods are heated in and then the rod is put in the piston an the pin is stuck in and and then when it cools everything is nice and tight.
what I'm interested in is knowing how you are going to get the pin back out.
.The old piston doesn't matter if it gets damaged I have already tested it and I can get them out pretty easily with a ball joint press iv already removed 4 of the 8 they came out fairly quickly.
I can't do that! Lol my old pistons are trash I'm just talking about installing new ones..
Say I'm interested in getting the Piston off of a rod so that I can put the piston on another rod.
I don't want to damage my piston.
Back to eating my chips and salsa.
This one hour time change has got my timetable all screwed up.
anodized is paint.... ??Don't paint them. We can gold anodized them.
.anodized is paint.... ??
i'm not familiar with that process.... learning time.
No anodized is not paint.
Anodized is electroplating.
