2019 summer race.... Jadaharabi vs 318willrun
who's got this race ?
  • J par - hard to beat a guy that has 4 of everything
    Votes: 7 14.0%
  • Jadaharabi - are you kidding me? this guy is working on a stock eliminator
    Votes: 23 46.0%
  • 318willrun - no plan, other than brain cramps thinking of one
    Votes: 20 40.0%
  • Total voters
    50
That was the main reason I decided against the magnum. That and the price of replacing a roller cam!
at these prices, be better off to buy EQ heads with LA bolt pattern for the intake. Most likely the factory mag heads are cracked anyways, besides, the EQ's flow better right from the box AND they are beefy so they don't crack AND they have stronger pedestals for the rockers. Now I'm convinced and should order a set! LOL :D
I want to figure out a way to just put la heads on a magnum! I have 2 extra sets of heads just laying around. Getting the oil up is the only difference right?
yeah. Some early mags have the oil passage opened. Most you have to drill.
Looks like a 2bbl Holley would set there! Hahaha
What happened to the price on those manifolds??!! The last time I looked they were in the $200 range??
I'm not sure if it was 2 years ago or 3, but I remember the Chinese knockoffs were 160 bucks on ebay.
I noticed this note on the new trick flow head.
Might look into it for standard LA heads.
Magnum engines must use Harland Sharp S72025K (1.5 ratio) or S72026K (1.6 ratio) shaft mount roller rocker arms for proper oiling.
My dual quad 1995 is over $500 now...
It was barely over $400 when I bought it brand new..
My duel plane M1 mag intake was $350 new from Chrysler, look at e-bay now for the going rate.
Let alone price a used 6-pac small block intake. There were a lot of 6-pacs at Carslile last year, intakes were in the $1500 asking range.
Gold wheels worth 3 tenths??? :D
j par probably changed his vote, he seems to be in love with Gold... LOL
How am I going to change my vote? I've got 40 bucks riding on this! Who was it that I bet by the way dammit? Jabs is going to get that dart together and school you in the Fine Art of getting your butt whipped!!!!
I think I bought like gold glitter instead of a gold metallic. When I spread it in the cap it just started to make big clumps! Dammit LOL.. there goes eight$ down the tube.. I'll use it somewhere else I'm sure..
I went with painting the inner ring silver as the car of course is bare metal and silver and the center caps Chrome so I thought it would Set It Off nice. at the very least they gave it the in effect I was looking for as you don't see the kidney shaped holes with the dark background.
I put the silver stripe on each back rim under the hub caps for at the drag strip. I like the way some of the old school drag cars would paint the rims half and half or put a white stripe so you can see how much faster the wheel is going than the Earth is turning LOL...
View attachment 1715332194 View attachment 1715332195
View attachment 1715332197I put the silver stripe on each back rim under the hub caps for at the drag strip. I like the way some of the old school drag cars would paint the rims half and half or put a white stripe so you can see how much faster the wheel is going than the Earth is turning LOL...View attachment 1715332198
:realcrazy:
