actually leaves circular marks... you can see it in this pictureIsn't planing straight?
One intake bowl...…. 2.02's were installed where 1.88's used to be, the bevel out is …. wow... LOL. Not taking chances, opening things up safely. REMEMBER, you have to think INHALE on the intake.... opening up for syphon from the picture angles. More work to do...…
thanks. I will buff the exhaust runners to dull the casting. The intake runners will get the push rod area massaged, and the valve cover bolt lump removed.Are you going to tackle the runners ? BTW , looking good
I don't know for sure. They were already re-done 308's with new 2.02's installed, and new exhaust valves/seats.Let me guess, the heads were done on a storm Vulcan?
I have a big problem with my milodon pan. But, much different than yours also. It looks like yours is one piece where mine is several welded pieces not very well I might ad...Todays adventures included going for groceries, somemore cleaning out behind the dart and finally after several months picking up a milodon stock pan.
Looks like it was done with a blanchard grinder (sp).actually leaves circular marks... you can see it in this picture
Pictures ? I will thank you in advance, LOL
A very accurate way to get a flat surface, we have a few at work.
I agree. We do RA and RZ finish test also. I could measure these with a pocket perthometer, or a contour tracer. But, I agree with what you say, it's a great finish for the application.You can control the RA on finish with a grinder, depending on which grade stone used.
That looks really rough for a surface finish, I am used to seeing 63 RA finish on products we make. Super smooth.
But I work in the aircraft industry, that looks in the photos to be a RA 125 or greater, which will give the head gasket some bite.
Nothing wrong with it for the application.
part number on this please?Todays adventures included going for groceries, somemore cleaning out behind the dart and finally after several months picking up a milodon stock pan.
looks like a nice panI picked it up at their store here in peoria and saved shipping. Plus did it across the counter instead of thru ebay and they saved on the fees.
thanks, but I will pass means I just purchased the one from here (even though it's a stock pan with no baffle). It should work for my needs.They have 1 left for 360s. and a couple for 340 that are $10 cheaper that the 360 ones.
Want me to pick one up for you?
