That early in the year would almost certainly be a '67I looked on my engine and found numbers on passenger side they are 1-20-67. Does this mean it is a 67 engine or a 68. I'm confused I had someone say if it is stamped 67 that they went in 68 vehicles. Thanks you
There are some numbers stamped on the front of the block just below the driver side head like C273 and a number?
What is the scheduled build date on the data tag on the car?
Alan
There is a 273 before these numbers. Also where do i find the schedule build date on data tag . You talking about fender tagThere are some numbers stamped on the front of the block just below the driver side head like C273 and a number?
Alan
Here is numbers under the cylinder head on drivers side it has a 273 before these #'sI looked on my engine and found numbers on passenger side they are 1-20-67. Does this mean it is a 67 engine or a 68. I'm confused I had someone say if it is stamped 67 that they went in 68 vehicles. Thanks you
So what does the 510 mean. I know for most part it just I’d number. I got a picture of mine
If that means May 10. Mine has 207. Which would mean Feb 7.So does that mean May 10?
And with block stamped 1-20-67 that would mean the block is a 67 I guessIf that means May 10. Mine has 207. Which would mean Feb 7.
Anything cast and stamped in Jan will be that year. That is 5 months into the production year. Mid year. Now, never say never. Now, it is posible for a block to be cast and not assembled until a few months later or assembled and not installed for a few months but that has rarely happened that I have heard.And with block stamped 1-20-67 that would mean the block is a 67 I guess
Yes mine are adjustableI'm not sure to be honest. Does yours have adjustable rockers? I believe they changed to hydraulic in 68.
If that is the casting date then it is the date the block was cast, hard to say when it was machined. The engine assembly date is stamped on the front of the block just below the head.And with block stamped 1-20-67 that would mean the block is a 67 I guess
