Good mention
i know what you mean, i've looked at cars before that were listed as 'never been welded'. the fact that every panel needed at least some welding seemed unimportant to the sellerNo, FYI, I'm tired of looking at junk. It's unreal people who don't understand the difference between a project car and one that doesn't need any body work. Seen one awhile back the owner said it was rust free, he should have said that it was metal free.
I hear you. I don't know if it's common practice, but I always have engine balanced when it's rebuilt.Make up a parts/machining list for both 273 and 318. You will be surprised how pricey the 318 can get.
I was looking to do the same thing for our 67 cuda. With varying piston weights you could be into a "rebalance". Up here that's approx $600.
Is the 273 2 or 4 barrel?
Egge and is it Canton/Kanter make the Commando pistons.
There was a member on here about 4/5 years ago that did a drive by here that mentioned he bought some Commando pistons, but no reviews from him.
Good luck
I put the 4 barrel Egge's in my 273 builwere perfect! perfect!Make up a parts/machining list for both 273 and 318. You will be surprised how pricey the 318 can get.
Good luck
I don't remember. Kanter I believe. They had green Teflon on the skirts.Do you remember the guy that posted about commando pistons?
It’s a’67 4barrelWhat year car are we talking about? And what motor 273 2 barrel or a 273 4 barrel motor?
It’s a’67 4barrel
You claim it's not going to be "just a drag car" which indicates to me that it might see a bit of track time though. If you have access to an inexpensive 318 block, I'd use it and keep the original 273 block in cosmolene stored away for any potential future restoration. I'd then reuse all the other 273 parts in building the 318 so you can keep the original look. As Professor Fate mentioned, you'll need to do something about the mismatch of a A500 converter to your small register 273 forged crank. Either machine out the end of the crank, or, if possible, I'd get a custom converter built instead. Another option would be to use the 318 crank, which they made in both cast and forged. Either one will handle the horsepower you'll likely end up with.I’ve got my 273 torn apart, and need to decide which way to go. All original engine. Crank and rods are fine. One cylinder won’t clean, so it will need bored. Do I stick with 4bbl pistons, or by 318 pistons like kb167? It would bring compression down about a point or so, the way it’s sounding.
I plan on running 3.73 gears and putting in an A500 overdrive. Try to stay with like the Isky E4 cam. I want to make an all around good driver, not just a drag car! All opinions welcome.
These cars are 50 plus years old now... ya had to buy them in the 1990s when they were half as old to get a good one. I don't mean to sound negative but you aren't going to find a pristine car for cheap now even a nice 4 door 70s Dart or Valiant is 7 to 10 grand.No, FYI, I'm tired of looking at junk. It's unreal people who don't understand the difference between a project car and one that doesn't need any body work. Seen one awhile back the owner said it was rust free, he should have said that it was metal free.
Fixed67 Dart, Charger 273 is a pretty sweet combination. Keep the hp 904 and just run 3.23 gears.
That’s a great little motor. But you can’t beet the cubic inches. Old 318’s should be a dime a dozen. A 60 over 318 makes 331 and with flat tops it would be a scremer. Or you could leave the 273 in. Just saying the money you spend will be the same. I had a beautiful 66 dart 273 hipo when I was 16 I put a 340 in it and never regretted it for one second. But that’s me.It’s a’67 4barrel
10k will buy you a project car in Missouri. I'm sure that I can get a nice car for 25k, not perfect but niceThese cars are 50 plus years old now... ya had to buy them in the 1990s when they were half as old to get a good one. I don't mean to sound negative but you aren't going to find a pristine car for cheap now even a nice 4 door 70s Dart or Valiant is 7 to 10 grand.
Didn’t you lose a lot of compression?Pretty funny, I kept the 273 Commando bottom end and added the 340 top end. 340 is still on the engine stand. Never regretted that either.
Build a 340 or 360 and throw a 273 badge on the air cleaner. Tuck the original engine away so it can stay with the car if someone wanted to go back original.
