who's upgraded their fuel line to 3/8? what did you do, who sells lines for an early a? i would like to stay away from aluminum lines.
I know you said you wanted to stay away from aluminum, but I went with the 1/2" Summitt aluminum fuel line. It was real easy to work with. To insulate it I took 1/2" rubber hose and covered it in that. It worked like a charm.
I had a 63 dart 440. /6. Push button trans. White. You car brings back memoriesI went with stainless steel brake and fuel lines throughout my Dart. SS is a little hard to bend and it's best to have the flaring done by a shop. I had -6 steel ends welded to my hard lines and I'll connect using braided line from the fuel pump in and out. I'll also go braided from the hard line in the engine compartment. I got all my lines from FineLines.
About 2 hours away from Tampa on a good dayToooo cool!!! These guys are in Daytona!!!
Hydraulic Supply Co.
970 N. Clyde Morris Blvd #132
Daytona Beach, FL 32117
Tel: 386-274-4617
Right down the street from me!
And the tubing, too!
Page Not Found | Hydraulic Supply Company Hydraulic Supply Co.
P.S. Longarm, you should paint that line with the Rustoleum rust reformer and top coat it to your liking (or leave it flat black) after you have it all bent the way you like it.
Out of curiosity, why would you like to stay away from aluminum?who's upgraded their fuel line to 3/8? what did you do, who sells lines for an early a? i would like to stay away from aluminum lines.
I had a 63. It had themOff topic but did your car come with the “DART” emblems on the front quarter panel or did you buy them? A previous owner removed them and Bondoed the holes for them. Would love to get them back on. Thanks!
They look great and I was pretty sure I was missing them. Can’t seem to find anyone obvious who reproduces them so I’ll need to huntI had a 63. It had them
813 340 3831. Chris. He may have oneThey look great and I was pretty sure I was missing them. Can’t seem to find anyone obvious who reproduces them so I’ll need to hunt
