rigger3006
just did compression test on my smoking 318, 30 psi on 5, the rest averaged 120, 284/ 484 cam, while testing other cylinders oil was flying out of no. 5, added oil to cylinder and still 30 psi , rings?
Remove #5 plug. With your finger in the hole, have someone bump the engine until you feel compression just begin to blow against your finger. Then, use a long this screwdriver and place it against the piston. Bring the engine on around by hand until that piston is all the way UP as far as it will go. If you feel it JUST begin to go back down, that's ok. You have just gotten #5 up on the compression stroke and closed both valves on that cylinder.
Now get a compression tester hose and screw into #5 plug hole. Then attach a live air hose to it. If you hear escaping from the carburetor #5 intake valve is not seating. If air escapes from the tail pipe, #5 exhaust valve is not seating. If air escapes from the valve cover breather, you have a broken ring or a hole in that piston. I am betting on a burned exhaust valve. Wherever air escapes, you WILL know it.
You make get a small amount of air in other areas, but wherever the problem is, will be very obvious.
Or........yank the valve gear off that side so the valves are closed and apply air.........
I'm not seeing any way you're not going to be pulling the head ??
Glad to hear it will be a (relatively) easy fix. I didn't expect you to go willy-nilly pulling the head off without do proses as some would've suggested.
120 is too low for that cam.
The 340 cam was a much better match, but if you advance that 484 enough after you fix the problems with the engine, you can get it right back up there.
