mderoy340
If your replacing the timing chain you might as well put a cam in.
Jegs has the same cam cheaper than Summit. Summit will price match. Use trickflow valve springs.
The 68 340 cam was not designed for low compression motor. Many will argue that point.
JEGS Performance Products 200160: Hydraulic Flat Tappet Camshaft & Lifters for Chrysler: 1964-Up 273-340-360 and 1967-Up 318 | JEGS
Trick Flow® by PAC Racing Single Valve Springs TFS-16901-16
