That's a good looker for my situation I think.
It is. It will also take the 901 spring which is cheap and you can even still use the stock rockers.
I'm used to a little clatter with my 273. It's kinda cool!They do take advantage of the .903 lifter diameter. I agree it may be a little fast rate for an everyday driver. A little valve train noise, and somewhat harder on the valve train than the DEH Comp.
I
Take a look at the Comp 255DEH.
20-416-3 - Dual Energy™ Hydraulic Flat Tappet Camshafts
It will work very well for you.
Here is one in a 302 Ford. Sounds good.
The stock 340 cam is 268/276 .430/.444 It has 18° more intake duration and 16° more exhaust than the XE250H that Moparmandan used. The lift is about the same. I wish I had the @.050 specs on the 340 cam. May'be someone will chime in with them. The smaller the engine the less they can tolerate duration and still be mild enough on the street without a converter and/or gears. With a stock Teen and say a 4 barrel and dual exhaust I wouldn't go bigger than the XE262H. Do you happen to have the stock specs for the 318 and 360 cams? I don't right off hand. They were pretty anemic if I remember correctly but a 360 cam in a mild 318 is a good step up from what a few said that tried it. Any cam that's bigger than stock specs is a improvement as long as you don't go too far.
It's been a pleasure chatting here but we have polar opposite opinions about what rustyfish can use in his 318 powered Barracuda. He's not building for maximum horsepower, he just wants a fun and peppy engine with minimal modifications to make it work.If you lool at the 0.050" spexs both 340 and xe250h cams are similar. Think of the xe250h as a fast ramp tighter LSA version of the 340 cam.
(That duration is miles apart in a stock 318 and no way would I call the XE250H a version of the 340 cam)
Im sure the 360 cam in a 318 gives a nice little bump but I think its to conservative.
(A little bigger cam is way better than one that is obviously too big.)
I totally agree with you when you say idle to 3500 is a very important powerband for a street engine. In normal driving my tach rarely goes above 2000 rpm.
(So lets not look at the dyno sheets you posted. They start out at 3000 rpm. Hot Rod was going for maximum horsepower at 5500+ rpm. We are talking about power and torque from idle to 3000rpm. )
And especially if you got everything going against you eg. Heavy car, small engine, high gear, low stall etc..
(It looks like the OP has a 66 Barracuda with a 318, stock converter and a 2:70 something gear. 2 out of 2 there.)
But I think people shouldn't just go super conservative either.
(I would call the stock cam super conservative but with a stock 318 there isn't much room between stock and that 220° @.050 duration number where it won't isle low enough a converter, doesn't have enough vacuum for power brakes and needs a 3:73 gear to get away from the stoplight.)
Take the two mopar magnum create engines which I basically own both. 300 has stock cam and the 380 has a fairly stout cam.
I got magazine dyno of both below.
*note the 300hp one does start to 3000 rpm but looking at the curve both are probably the same or close at 2500 rpm.
I got the 380hp in a 68 Valiant with 2800 stall, 2.96 gears and 27" tires with an effective gear ratio of 2.63.
And I dont exactly have 300hp create but a 98 5.9 jeep which is pretty much the same besides 4bbl and headers. Its heavier and 3.73 gears and 32" tires with an effective gear ratio of 2.80.
If you compare the two dyno charts the 380hp engine meets or beats the 300hp from 2500 rpm plus except one point. Which is the peak torque of the 300hp has a slight advantage.
Driving both the valaint is a little soft under 2000 rpm. Which I blame more om the intake, single plane M1 then the cam.
Theres a dyno shoot out between the M1 and Airgap an the airgap made 20-30+ lbs-ft all over the bottom end.
Where the 5.9 jeep pulls hard from idle and if weighed the same as the Valiant would definitely be the better under 2500 rpm choice.
(The Magnum comparison is nowhere close to the op choosing a cam for his stock 318)
But doesn't mean the stock cam is the winner for a daily driver or down low performance. Theres a big cam difference between the two. Lots of choices, Im sure something like a 265 or 268 cam would give 90% of top and bottom. Basically having your cake and eatting to.
(There is no "magic bullet" camshaft)
I think the trick is finding the cam thats gonna give you the most top end with out effect bottom end too much. Or a compromise that works for you.
(I will say it again, there is no magic bullet cam. If you make some power and torque at low rpm it goes away at 4500 or so. If you make big horsepower at 4-6000+ rpm you don't have much down low. Sorry about the cake. You can have it but you can't eat it)
The modified Hp and Tq is eddy heads and bigger cam something like a 275
(Who even cares about that. Those numbers don't mean anything for the op's stock 318. Again, the Hot Rod dyno chart really doesn't tell us anything we can use here. Again, back to the stock 318 thing!)
After all the threads I've read through almost seems a waste of time to go there.
Getting ready to do some engine mods after the front end gets a complete rebuild kit. Once the engine is done, I'll actually get to start enjoying the car some for the first time.
Installed a new gas tank, seals and lock ring.
Upgraded to dual master brakes.
Done many of the electrical mods. Headlight relays to come down the line.
Pulled the cluster and refurbishing that as I type.
After the front end, I have an LD4B and Edelbrock 1406 ready to go. I also pulled some 302 heads from the junkyard for $10 that need going through and valve job.
I'm just questioning whether I really need to add the expense of the cam to this and whether it'll make that big a difference.
I have the 904 column shift and original 71/4 and don't plan to upgrade as I already put in new leafs.
Car will just be for cruise nights etc. but I wouldn't mind be able to move a little bit on the street once in a while.
I have power steering and column shift so headers are unlikely.
Thanks for that Rusty, but that combo gets me in trouble with fitment. I have power steering and column shift so headers are unlikely.
What headers did you use? Only seen one set that could get through that and they were semi customWhy? I put them in my car. Just had to dent one of the tubes slightly to clear the steering knuckle.
And you have power steering and column shift?Cheap Summit headers.
@ .050" specs for the stock 340 cam are 208 intake, 214 exhaust.The stock 340 cam is 268/276 .430/.444 It has 18° more intake duration and 16° more exhaust than the XE250H that Moparmandan used. The lift is about the same. I wish I had the @.050 specs on the 340 cam. May'be someone will chime in with them. The smaller the engine the less they can tolerate duration and still be mild enough on the street without a converter and/or gears. With a stock Teen and say a 4 barrel and dual exhaust I wouldn't go bigger than the XE262H. Do you happen to have the stock specs for the 318 and 360 cams? I don't right off hand. They were pretty anemic if I remember correctly but a 360 cam in a mild 318 is a good step up from what a few said that tried it. Any cam that's bigger than stock specs is a improvement as long as you don't go too far.
I wound up going with the Whiplash cam. It retains the low end torque and the idle I was looking for.
It no slouch on the top end either.
