MObarracuda
How about this oneNo, That's not a VooDoo grind. The VooDoo grinds are split pattern cams, which I believe will work better.
Brand:Lunati
Manufacturer's Part Number:10200701LK
Part Type:Camshaft Kits
Product Line:Lunati Voodoo Cam and Lifter Kits
Summit Racing Part Number:LUN-10200701LK
UPC:788120732703
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,000-5,500
Intake Duration at 050 inch Lift:213
Exhaust Duration at 050 inch Lift:220
Duration at 050 inch Lift:213 int./220 exh.
Advertised Intake Duration:256
Advertised Exhaust Duration:262
Advertised Duration:256 int./262 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.475 in.
Valve Lift with Factory Rocker Arm Ratio:0.454 int./0.475 exh.
Lobe Separation (degrees):112
https://m.summitracing.com/parts/lu...se1-_-lunati&gclid=CI3uqYritNMCFdS6wAodYaUD2A
