Awesome. I'll get to drawing it up in the next few days.
Your choice for the "1" with or without a lower bar.
With the foot would be my choice. How hard would it be to draft it each way?Awesome. I'll get to drawing it up in the next few days.
No problem. How hard would it be to draft it each way
Take a photo of the emblem and scale it to a size you like and try it on the scoop. Once you find the right size get me the dimensionProbably have to shrink the whole thing down a little to make it fit the double hood scoops
I REALLY LOVE THIS!!! Even better if there was a "right" and "left" version (one slanted right - like these , one slanted left, so they would both be slanted forward on the scoop. Where did these come from????
Agreed but I ordered a pair of them to mess withAt least the "8" matches the "3" now.
I agree, needs L and R slant.
Just IMO, but that style emblem looks better on the fender.
This style looks "right" to me on a scoop or power bulge-
That would be perfect to have the pins the same as the 340 emblem. I could use a couple myself.I like that one too but I don’t think there is enough room on this scoop for that long emblem at least oriented the same way.
We used the factory 340 pin holes to locate this one in the same space. To mount the longer one on the scoop, it would run uphill in the back? Like the 340 call-out, the emblem above sits parallel to the ground.
We used the factory holes!That would be perfect to have the pins the same as the 340 emblem. I could use a couple myself.
That looks perfect!Update. I sent @Dana67Dart 's emblem file to an online vendor to have printed in 316L steel. I chose the polished option but you could still see the print layers. I spent some time sanding the surface with some 1200 grit paper until the print layers were leveled out. I painted the emblem then wiped off the surface while the paint was still wet leaving the sides in black. Turned out pretty good!
He did a bang up job on the drawing! I’m going to final sand the surface tomorrow then shoot it in clear coat.That looks perfect!
$30 a pieceGotta ask how much that cost.
for sure. these are smaller though too. the numbers are the same size as the 340 hood scoop callouts. but yea, $60 and a little sanding/paintwork for a pair isn't bad.That's better than the repro 383/440 badges!
I guess we could see what the interest is and go from there!Any chance you could arrange a bulk buy if folks paid up front?
