Bakerlite
- Joined
- Nov 12, 2007
- Messages
- 6,431
- Reaction score
- 3,311
First of all before I post anything, I'd just like to thank bohica2xo for his help with this project. Thanks man!
OK, to start with, this build will be based on the the Martin system from back in the 80's. Really I think it's a great way to turbo your car. The carb stays pretty much in it's original location but will sit about 3 inches higher than it normally would.
I am posting some pics here of the chamber that will connect to the turbo.
The bottom of the chamber has reed valves to bypass the turbo when there is no boost,so the car will drive as if there is not turbo fitted. Once boost starts to rise the reeds shut and boost is supplied. No turbo lag.
The manifold will be modified so that the turbo output goes under the base plate.
I have the reed valves on the way as well as some block hugger headers. I won't modify the bottom plate until the valves arrive. When the headers arrive I'll mate the turbo to them. Until then there is not much else to do accept add a fitting to the base of the intake manifold.
I'll post more pics as I get more done.
Sorry but for some reason my camera decided to take blurry shots.
