So all cylinder from the right bank blow exhaust gas into the front and rear exhaust ports on the left bank.... Where exhaust gas is also trying to get out?? And the turbo is only driven off the 2 centre cylinders on the left bank? Won't that just choke the engine to death like blocking the exhaust.
Excuse the ignorance but I've never seen a setup like this! I can clearly understand the draw through (cold side) but the exhaust has me baffled.. No pun intended
This exhaust setup does look confusing... But the left bank and the right bank are joined and all exhaust gases exit via the 2 center left exhaust pipes through the turbo.
At first glance it does look like it would be restrictive but no more so than going through the turbo.
Bakerlite has Bohica2xo helping him and from what I've read of Bohica's posts, he is one clever guy.
the draw through on the intake makes sense to me
what baffles me is the the left and right join together at the bottom, That's right and from there all exhasut gases exit the turbo
but I only see about a 1 inch passage from the rear to the center ports That's right
and front one doesn't join;Front and rear join where the right bank joins the left header
and has to blow into back pipe which in the end goes through that 1 inch opening No, it all goes out the center 2 left exhaust tubes and then through the turbo
they should be like a double shorty header and exit bottom and top, bottom should cross to other side and top enters the turbo, what I see will not allow engine to run let alone build boost
Cool build but it leaves me confused and with a headache.
I think you're overthinking it, all exhaust exits the turbo it just takes a few twist and turns to get there. Anyway that's how I see it.:thumbup:
what baffles me is the the left and right join together at the bottom, but I only see about a 1 inch passage from the rear to the center ports and front one doesn't join; and has to blow into back pipe which in the end goes through that 1 inch opening
if you have to send #2 exhaust fumes going through #8 pipe thats quite abit more then what it should have to and won't have time to clear before #2 hits again, having headers are supost to prevent that not make it worse
I think you need to forget header theory when dealing with a turbo as the turbo will be the biggest restriction in the exhaust, think of log headers versus tuned headers. tuned headers don't gain much over a log design when pushing through a turbo.
So cylinder #1 and #7 join up with #2,4,6,8 under the engine and then they all flow up to #3 and 5 and then out through the turbo.
as you said there is no need for a for a blow through carb since it is not pressurized
yes but # 3 and 5 pictured are only connected to the rest of the 6 cylinders with a 1" or less pipe, if your feeding 6 cylinders into a 1" pipe your bound to have problems
correct me if I don't see something I should because I really am trying to understand and not trying to flame anyone
I'm confused as to how all cylinders besides #3 and #5 can get their gasses to the turbo? Am I overlooking something here?
From what it looks like you will only be feeding the turbo from 2 cylinders and the rest will be fighting each other
Exhaust gases will flow to the point of least resistance which is the turbo outlet, not the other cylinders.
The exhaust gases might be "crashing" into each other but they'll get over it and exit out the turbo.
Your setup wardy is the way you want to be doing it, but for what bakerlite is trying to acheive this exhaust will work fine.
